Is it my transfer case mounts or tranny mounts? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Is it my transfer case mounts or tranny mounts?
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 08-20-2012, 01:59 PM   #1
zerocool333
Would my symptoms be related to tranny mounts or transfer case mounts?
Symptom 1 - When gassing it fairly hard the front driveshaft hits the crossmember on skid plate (didnt do this before only recently. also it's an automatic)
Symptom 2 - Clunking sound when wheeling over rocks and bumps. Sounds like its coming from the tranny area.
Not sure what else it could be.
thanks in advance.
zerocool333 is offline   Reply With Quote
Unread 08-20-2012, 02:01 PM   #2
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
drop trans/t-case crossmember and look at the trans mount. see if the rubber is cracked.
make sure to support the transmission with a jack.
Unlimited04 is offline   Reply With Quote
Unread 08-20-2012, 02:07 PM   #3
zerocool333
I'm not sure if it's called the "crossmember" but it's the skid plate "arm" in the pic below. You can see the ring from it rubbing in this photo...
Unread 08-20-2012, 02:10 PM   #4
greene69
Beach Bound
greene69's Avatar
Don't think the transfer case has a mount. If not the trans mount check the motor mounts.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline   Reply With Quote
Unread 08-20-2012, 02:10 PM   #5
TheRealKTrain
that looks wrong. As if you have zero clearance when the axle is drooping...
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline   Reply With Quote
Unread 08-20-2012, 02:11 PM   #6
MO2500
Fabramicator
MO2500's Avatar
There isn't separate transmission and t-case mounts, just the transmission mount supported by the belly skid plate.
The stock auto trans skidplate forward of the belly skid needs to be removed with a lift or the driveshaft will rub. Consider picking up an aftermarket trans/engine skid to replace it so you still have something protecting the pan.
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Unread 08-20-2012, 02:16 PM   #7
zerocool333
Ok that makes more sense.
That's what I thought except I was driving around for a few months and never had the DS rubbing issue until recently.
Unread 08-20-2012, 02:17 PM   #8
TheRealKTrain
that explains it! thought it looked goofy. You silly automatic tranny drivers!
Μολὼν λαβέ
Unread 08-20-2012, 05:30 PM   #9
Unlimited04
yup, you need to remove the 42RLE transmission skid with any sort of lift.
Unread 09-04-2012, 09:35 PM   #10
zerocool333
Update: So I found the clunking source! I was way off. Turns out it was my rear sway bar link.
I did check the transmission mount and it was good so I just removed the smaller skid.
