My TJ has the shakes - JeepForum.com
post #1 of 11 Old 11-28-2011, 12:26 PM Thread Starter
NakedCreekTJ
Okay so i have a 98 5spd 6cyl with a 2.5" RC lift and 30" A/T. Here recently my jeep has began to shake when going around gradual turns at speeds from 40mph - 70mph. It will shake violently until i slow down to about 20mph or slower. I realize its not a death wobble but it is so violent that i cannot just keep driving and it will stop, i have to slow down imediatly.
I do not have sway bar connects and im not for sure but i think my tierod is bent. I feel that this may be the issue, but before i started buying replacement parts I wanted to get some feedback on what my fellow JF's think.
Thanks guys and any input is welcome!
___ ___
[l_,[____],
l---L - OllllllO-
( )_) ( )_)--)_)
NakedCreekTJ is offline
post #2 of 11 Old 11-28-2011, 04:52 PM
mukluk
Check your steering components for wear and loose hardware, also check the control arm bushings for wear. To rule out any alignment issues, go here --> http://www.4x4xplor.com/alignment.html
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 11 Old 11-28-2011, 04:56 PM
TheOrffs
Tie rod end bushing maybe?
TheOrffs is offline
post #4 of 11 Old 11-28-2011, 05:04 PM
Necromancer_tat
Where'd all my money go?
Check the Track bar bushing and tre for play.
Necromancer_tat is offline
post #5 of 11 Old 11-28-2011, 09:21 PM
wolfcreek
Not sure why you say it's not death wobble - sounds very much like it is.
wolfcreek is offline
post #6 of 11 Old 11-30-2011, 08:39 AM Thread Starter
NakedCreekTJ
Perhaps it is.. I was just basing my information from what others have said. And the tierod ends are good checked all of those. I believe my draglink may need to be tightened and the control arms need to check those. I also did the alignment and that didn't seem to help. But I do appreciate the input and keep the ideas coming I'm checking them all as I go.
___ ___
[l_,[____],
l---L - OllllllO-
( )_) ( )_)--)_)
post #7 of 11 Old 11-30-2011, 09:57 AM
JeepManager
Just had the same thing going on. I knew it wasn't my steering cause I had just replaced that, and found that it was a lower ball joint that was just barely gone. Not enough to tell with the wheel on unless driving, but on close inspection is was and the replacement of it fixed everything.
Hope that helps.
JeepManager is offline
post #8 of 11 Old 11-30-2011, 10:05 AM
jkjrngn
Check your u joints, I had a shake when I got to 55 and replaced the front right wheel u joint and now I only get the shake on bumbs, I Jose replaced my track bar bushing and a rr steering stabilizer but the u joint did it for me, it's also pretty cheap if u do it yourself
jkjrngn is offline
post #9 of 11 Old 11-30-2011, 11:03 AM
RowJ
First things first! I agree with "Mukluk'
Since it's intermitant, I would crawl under her and check ALL connections for loosness.... especially steering components, track bars and control arms. Ck front and back! Retorque wheel bolts , just for good measure.
How many miles in this TJ?
RJ
RowJ is offline
post #10 of 11 Old 12-01-2011, 08:48 AM Thread Starter
NakedCreekTJ
The Tj has 154000 on it roughly... I bought it at 151. I've been off roading and enjoying it. So by my inspections I'm being to thing that my drag link was just loose I tightened down on it, although it didn't seem to move to me... The shaking has gone away momentarily. However I can see some wear on the balljoints that probably are soon due to be replaced
___ ___
[l_,[____],
l---L - OllllllO-
( )_) ( )_)--)_)
post #11 of 11 Old 12-01-2011, 09:39 AM
JeepManager
Check this thread about the same thing.
http://www.jeepforum.com/forum/f9/death-wobble-1295392/
death wobble , disconnect , problem , shaking , tie rod
TJ with the shakes Dalke-cj TJ Wrangler Technical Forum 2 09-30-2008 06:54 AM
Shakes Feigle TJ Wrangler Technical Forum 5 03-15-2007 03:04 PM
Help with the shakes! younixguru YJ Wrangler Technical Forum 3 07-25-2006 12:03 AM
the shakes? jeepmud YJ Wrangler Technical Forum 5 09-14-2005 06:25 PM
got the shakes tat2freke TJ Wrangler Technical Forum 5 11-29-2004 03:14 PM
