My Tire Dilemma.. - JeepForum.com
post #1 of 12 Old 07-30-2009, 04:09 PM Thread Starter
FourbyFour
FourbyFour's Avatar
My Tire Dilemma..
I currently have 32 x 11.50 Pro Comp mud terrains and are more than satisfied. They are nearly worn out ( its been about 3.5 years)
I have a 6spd, '06 with 3.07s out back. Currently, I have no complaints about gas mileage or performance. I don't offroad much at all and whenever I do its very light.
I'm thinkin about going for their 33x12.50..
My dilema is the 32's only measure 31.4" tall and the 33's actualy height is 32.5"....i'm wondering with this specific tire if I could get away with it...
what do you guys think?
FourbyFour is offline
post #2 of 12 Old 07-30-2009, 04:12 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
It makes no difference.If you can deal with 3.07's and 32's,33's won't hurt anything.
TheBoogieman is offline
post #3 of 12 Old 07-30-2009, 05:03 PM
doubleroost
Just make sure that extra half an inch on each side of the tire isnt going to rub on anything. You should be ok though.
doubleroost is offline
post #4 of 12 Old 08-02-2009, 03:49 PM Thread Starter
FourbyFour
FourbyFour's Avatar
bump..forgot to ask..i have 15x8 steelies on there now..i'm guessing I would have to go wider?
Originally Posted by Jerry Bransford View Post
You'll play hell cutting in front of any veteran waiting his turn to piss on Jane Fonda's grave and you sure as hell won't cut in front of me.
Originally Posted by DcMuff View Post
PREPOSTerous...
Originally Posted by Dead_End View Post
hurr durr I gots a truk
post #5 of 12 Old 08-02-2009, 03:57 PM
emev0l
As long as they have 4.5" or less of back spacing they will be fine.
What size lift do you have?
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #6 of 12 Old 08-02-2009, 03:59 PM
-sean-
-sean-'s Avatar
1944 CJ2
As the others have already stated, you'll be fine.
-sean- is offline
post #7 of 12 Old 08-02-2009, 04:34 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
15x8 is perfect for 12.5" tires though I'd sure start saving up to regear your axles to a lower ratio. 3.07 with 33" tires is gonna be a real dog, performance wise.
By the way, I sure like your new signature. As you can see, I'm a real fan of Jane Fonda.
Getting
Jerry Bransford is online now
post #8 of 12 Old 08-02-2009, 04:41 PM Thread Starter
FourbyFour
FourbyFour's Avatar
Thanks Jer lol, ..i don't mind how the performance is now with my 32x11.5's (actual height is 31.4) so I figured id stick with the same tire and just go an inch bigger..which happens to also run shorter than advertised at 32.5".
I go wheeling probably once a year and it's very light trails so breaking the axle shafts isn't a big concern really..plus I have a set of Yukons sitting in my shed that are supposed to be a little stronger.
My main fear is that the 1" increase will be a HUGE difference...
PREPOSTerous...
post #9 of 12 Old 08-02-2009, 04:45 PM
Jerry Bransford
Administrator
To me, that last inch can be the straw that broke the camel's back.
Getting
post #10 of 12 Old 08-02-2009, 04:47 PM
Xlr8n
1986 TJ Wrangler
My advice is your fears will be realized as the difference between the 32's and 33s on 3.07 gears will be night and day. I was suprised what a difference it made on mine when I went to 33's...and I have 4.11 gears. Listen to Jerry, it'll be a pooch on or offroad.
Your only saving grace is the 6 speed tranny can ease the pain to some degree of being undergeared, but since you state you don't wheel much anyway you have no real need to go up in tire size and further lug the drivetrain.
In other words: You'll feel the difference much more than you'll see it.
Xlr8n is offline
post #11 of 12 Old 08-02-2009, 04:50 PM Thread Starter
FourbyFour
FourbyFour's Avatar
I hear ya, guys. I'll have to look into re-gearing. If I recall 4.88" is the size for the best performance? What's the step below that and can you reccommend a brand?
PREPOSTerous...
post #12 of 12 Old 08-02-2009, 04:55 PM
Jerry Bransford
Administrator
For your 6-speed and 33" tires, 4.88 would be too low of a ratio. I'd probably go 4.56 though with your 6-speed's slightly lower ratios, you could get away with 4.10.
Getting
Tire dilemma tecumsa Wrangler General Discussion 5 07-20-2009 01:57 AM
Tire dilemma. 33's on a 98 TJ Sport? dbdraggin TJ Wrangler Technical Forum 14 07-28-2008 08:24 PM
Lift/Rack/Tire Carrier Dilemma MrKleen TJ Wrangler Technical Forum 4 04-25-2007 09:21 AM
Tire Dilemma Kentuckyarms TJ Wrangler Technical Forum 4 08-29-2005 09:54 PM
lift/tire dilemma Varsity Tyler YJ Wrangler Technical Forum 9 09-22-2004 07:54 PM
