My soft top won't fit - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My soft top won't fit
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 01-10-2009, 08:12 AM   #1
tjt756
I recently bought a 98 wrangler with a torn up soft top. so i bought a new after market top. it almost fits, but not quite. i can get it on, but the passenger side is so tight that I can't close the back window on that side, nor can I get the front clamp down on the passenger side. The driver's side is tight, but I got it all closed.
I'm wondering if my soft top hardware (which is old) could be bent a little in the wrong place. Are there any common problems or techniques to get it to stretch a little further?
It's so close to fitting, but I just can't get it. And I don't think this is just the case of a new unstretched top, because I'm a pretty big guy and I've used all my strength trying to get it closed. Something isn't quite right.
Thanks,
TJ
tjt756 is offline   Reply With Quote Quick reply to this message
Unread 01-10-2009, 08:19 AM   #2
rxl
What was the temp while you were doing it. A nice hot sunny day helps.
I bought "MY JEEP" for my wife
I bought "MY OTHER JEEP" for my daughter [she sold it]
I finally bought one for me
Canadian Jeep Club Member #7
99 GC limited
4.7 Quadradrive
97 TJ Sport
4.0 5 speed
99TJ Sahara
4.0 Auto
Sold to a life of blacktop
94 ZJ Limited
I6 Quadratrac
rxl is offline   Reply With Quote Quick reply to this message
Unread 01-10-2009, 08:24 AM   #3
doubleroost
Agreed, put the top in the house and get it up to temperature and try it again.
doubleroost is offline   Reply With Quote Quick reply to this message
Unread 01-10-2009, 08:39 AM   #4
thejafe
Good call. Also, in what order are you installing everything?
thejafe is offline   Reply With Quote Quick reply to this message
Unread 01-10-2009, 08:49 AM   #5
Dogman
Watch this, it really made it easy for me.
http://video.google.com/videoplay?docid=3864145999719173612&q=wrangler&hl=en
Dogman is offline   Reply With Quote Quick reply to this message
Unread 01-11-2009, 08:47 AM   #6
R.T.
You're right it could be something else but don't underestimate the increase in difficulty caused by a new, cold, top. If it appears all else is fine, get it warm, the warmer the better.
R.T.
Many men can do what others cannot, and most of it is useless - John F. Gilbey
2006 TJ SE, Flame Red, Black Soft Top, 1/2 Doors, 6 speed manual trans, BFG ATs & Rock Crawler Black Steelies.
[COLOR="Red"]Red[/COLOR] Jeep Club Member #389
R.T. is offline   Reply With Quote Quick reply to this message
Unread 01-11-2009, 09:53 AM   #7
djt283
Definitely agree with the temperature advice first. New tops (at least my Bestop) are very tight out of the box. I guess it's so as they stretch and wear they don't get too loose.
Another thing to check is the black nylon strap (about 3" wide) that connects the rear bows of the frame can get twisted or caught when you put the top up. Check to make sure it's straight because it will cause the problems you're desrcibing.
djt283 is offline   Reply With Quote Quick reply to this message
