Quantcast my seats are soaked, any tips for fast drying??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > my seats are soaked, any tips for fast drying???
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 04-21-2005, 09:16 AM   #1
wakeboarder 21
my jeep got soaked in a rainstorm last nite and it is suposed to rain for the next couple of days. how can i get the seats to dry out ???
i tried a leafblower but it just filled my jeep with exhuast fumes...
i also dont want it to smell like meldew in side
the tub is Hurc'ed so no carpet or anything
98 TJ
5spd,4banger
RE 3.5 __ 1" BL__RE front adj. trac bar__Currie Anti Rock sway bar__33 BFG M/T with some black steelies__K&N Filter__CB___ Durango 4x4 Front Bumper
building for 37s
[URL=http://orw.truckmoxie.com/mygallery.ten?id=4573]***PICS***[/URL]
wakeboarder 21 is offline   Reply With Quote
Old 04-21-2005, 09:18 AM   #2
river rat
Forum porn star...I guess
river rat's Avatar
I am at a loss. At least it's not cat pee.
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline   Reply With Quote
Old 04-21-2005, 09:24 AM   #3
Kajunjeepn
Kajunjeepn's Avatar
let it go until you can remove the top and let the sun air it out. My seats got soaked many of times and i used a plastic bag, I wouldn't get soaked. Once it stop raining I removed the top and let them dry out completely. It never left any smell or anything.
Kajunjeepn is offline   Reply With Quote
Old 04-21-2005, 09:49 AM   #4
JPLIVE
hair drier, that's what I use
99 Green TJ Sport
My Music
http://www.soundclick.com/bands/pagemusic.cfm?bandID=414969
JPLIVE is offline   Reply With Quote
Old 04-21-2005, 09:52 AM   #5
JeepCreepn01
$ It's Only Money $
JeepCreepn01's Avatar
try a wet/dry shop vac, it will suck alot of the water out
JeepCreepn01 is offline   Reply With Quote
Old 04-21-2005, 10:25 AM   #6
MCanavan
Use a hairdryer.
MCanavan is offline   Reply With Quote
Old 04-21-2005, 10:25 AM   #7
wakeboarder 21
yeah i just got most of the water out by pulling the drain plugs...
now its just the seats... im going to try the hairdryer when the rain stops
haha the good side it is washed all the mud off of my dashboard
98 TJ
5spd,4banger
building for 37s
Old 04-21-2005, 10:42 AM   #8
ColoradoTJ
A combination of things listed above should work great. Run a shop vac over it again and again and then finish it off with a hair dryer.
Clint
Colorado Jeep Club Member #60
My Jeep
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline   Reply With Quote
Old 04-21-2005, 10:47 AM   #9
RockRunner85
You can get a heat gun used to remove paint at your local home depot or lowes. They get 1000 degress so don't hold it too close. It will dry the seats real quick. Thats what I used last year.
Or worse comes to worse take them out and brin the seats in the house.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
The Reptile File
A discussion forum on geckos, lizards, snakes, and other reptiles.
RockRunner85 is offline   Reply With Quote
Old 04-21-2005, 10:49 AM   #10
got4-Lo
looks like ur gonna start a fire
stretched *** tj
[URL]webwheeling.com[/URL]
got4-Lo is offline   Reply With Quote
Old 04-21-2005, 10:53 AM   #11
RockRunner85
Nah it seems like it would, but it won't unless you stick it in the seat. It looks just like a hair dryer, but gets hotter. Alot of people use them for shrinking heat shrink for wires, peeling paint. I used it on my bros hockey sticks to replace the ends. There glued in and you have to heat it to 400+ degrees to melt the glue.
The Reptile File
Old 04-21-2005, 10:56 AM   #12
got4-Lo
i know what its ans i have one. a regular hair dryer shuold do it
stretched *** tj
Old 04-21-2005, 12:26 PM   #13
Tex77
Use a tub of Calcium Chloride.
You can buy it at Wal-Mart. It is called Damp Rid. Usually with the Household cleaning supplies.
Leave the top up. Close all windows and doors. Set a tub on each seat. The Calcium Chloride will pull the moisture out of the interior of your jeep. I would keep refilling the tub until the drain pan in the bottom of the tub stays dry.
This is a must to eliminate mildew. This fix won't cost you more than $10-$15.
Good Luck!
Tex77 is offline   Reply With Quote
Old 04-21-2005, 12:47 PM   #14
PDX_XJ
I want to take my top off, but I live in Portland Oregon (Read: more rain than sun). Is there a good (non-ghetto) way to prevent rain from soaking the seat?
For example, is there such a thing as waterproof seat covers?
  • Armor's Axiom: Virtue is the failure to achieve vice.
  • The sooner you fall behind, the more time you have to catch up.
PDX_XJ is offline   Reply With Quote
Old 04-21-2005, 12:48 PM   #15
RUB1CON
If you have a garage open both doors and prop a box fan on each side blowin on the seats over the night thats what I do when everything gets soaked I have never had a problem with smell I use Febreze(SP?) when it gets really wet
'03 Rubicon
RUB1CON is offline   Reply With Quote
Glock Forum
