My rubicon build thread slow - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My rubicon build thread slow
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 08-20-2011, 11:35 PM   #1
alex211
I decided to start a thread about my modifications to my rubicon.
Started out stock with 145,000 miles and drove fine. So I tore it apart and installed a Zone 3" lift. I just got done bolting up the lift tonight.
stock
after
I haven't driven the jeep yet since the lift but by looking at the rear driveshaft I'm probably going to get some vibes. The lift came with a t-case drop but I really don't want to install it. If it does have some vibes will a 1" mml cure them? I don't have a slip yoke but the driveshaft is single cardan on both ends and the pinion is pointing up a little too much.
I am planning on ordering a 1.25 body lift, 1" mml, and 3/4 spacers for the front to level it out. Next friday I'm getting paid so I'll be ordering some 33" cooper STTs and a set of Cragar soft 8 wheels.
Future plans for the jeep are, UCF tummy tuck, double cardan rear driveshaft, custom rear bumper/tire carrier, and Rokmen rear upper arms.
03 TJ
Build thread - http://www.jeepforum.com/forum/f9/my-rubicon-build-thread-slow-1255392/
alex211 is offline   Reply With Quote
Unread 08-21-2011, 08:26 AM   #2
lope
lope's Avatar
Good work there and it looks like you had a lot of it! It's hard to tell from the one "after" pic 'cause it's from an angle but it looks level to me already.
lope is offline   Reply With Quote
Unread 08-21-2011, 08:51 AM   #3
solarpower
Chances are that your either going to have to drop that t-case skid AND do a MML and you might get your angle ok enough for the stock shaft...or your going to need another rear drive shaft with a double joint at the case.
"typically" with a stock Rubicon you can get about 2 inches of lift and still run stock shaft without having to drop the t-case skid. A MMl only improves the angle slightly and is often used with a tummy tuck or to dial in a small lift.
Based on the amount of "up" you went from the pics I don't think a MML is going to help ya enough in itself.
78 CJ5
04 TJ "U" package
06 XK Commaddy
Jeep mods do not fix poor driving or stupidity.
solarpower is offline   Reply With Quote
Unread 08-21-2011, 09:14 AM   #4
1222
Make mine a Jeep!
1222's Avatar
Nice start and write-up, great pics too. Is that your garage, it sure is deep if so? If it was me I would have had something backing up those jack stands, a couple of tires or some extra bottle jacks. Anyhow I’ll be watching your thread to see how you’re coming along.
P.S. I miss my TJ, it was an '04 Rubi, black.
1222 is offline   Reply With Quote
Unread 08-21-2011, 09:51 AM   #5
alex211
Thanks for the replies, it's my dad's garage but yes it's about 40ft deep.
I'm hoping a mml will cure any vibrations, I really want to stay away from a t-case drop.
03 TJ
Unread 08-21-2011, 10:21 AM   #6
djfuzzy
Lookin good
Sent from outer space
USMC 2006-Present
Sold: 2000 TJ - D44/D30 with 4.88s, Advance Adapters SYE, Tom Woods CV, Vanco Big Brake kit, 35x12.50 BFG KM2s, ProComp Series 51s, Rough Country 4" Series II, Bilstein 5100 Shocks, Currie HD Steering, Rokmen Adjustable Control Arms, ProComp Adjustable Trackbar, Currie Anti-Rock, MetalCloak Front Bumper and Stinger, Warn rear bumper/tire carrier
djfuzzy is offline   Reply With Quote
Unread 08-21-2011, 12:13 PM   #7
alex211
Well I took it for a drive and there are no vibes at all, got up to 65 smoothly. I'm just going to order a 1.25 body lift and some spacers for the front and hold off on the mml. I didn't install the provided t-case drop either.
The steering wheel is a little off but I set the toe to 1/16. I'm not going to try to perfect the alinement until the spacers are in because they're going to throw everything off again anyhow.
03 TJ
Unread 08-21-2011, 07:33 PM   #8
alex211
I'm going to get the mml too, it has some real slight vibes from 30-38 which the mml should take care of.
03 TJ
Unread 09-02-2011, 11:26 AM   #9
alex211
Got the body lift and wheels/tires on.
03 TJ
Unread 09-02-2011, 11:36 AM   #10
wravyn
I know anecdotal evidence isn't too helpful but for what it's worth I am running a 3 in TeraFlex lift with 1 in spacers up front and no t case drop and I have no vibrations whatsoever... I am also still running the stock driveshafts on it (2006 Rubicon). I remember reading awhile back on rokmen's site that rubicons could run stock driveshafts w/o a t case drop with up to a 3 or 4 in lift, I'll try to find it.
2006 TJ Rubicon; 3 in. Teraflex lift on 33x10x16 BFG KM2s, ARB Snorkel, XRC Bumpers, Warn M8000 Winch, Extreme Hi-Lift Jack, KC Slimlites, Banks Monster Exhaust system, K&N Air Filter
wravyn is offline   Reply With Quote
Unread 09-02-2011, 11:38 AM   #11
alex211
I have no vibes with the mml, it had very minor vibes with out the mml but they're all gone now.
03 TJ
Unread 09-02-2011, 11:41 AM   #12
wravyn
Ya you should be fine with a 3 in SL with stock driveshafts on a rubicon, especially if you plan on getting adjustable rear arms.
Unread 09-11-2011, 06:04 PM   #13
alex211
Took it wheeling this weekend and everything was working great ...
Until I was coming out of a rutted raving on the throttle and I slid into a tree. It was kinda bouncy coming out of it and my foot landed on the throttle instead of the brake resulting in this.
It actually pushed the rad into the fan and bent the grille a little. I'm going to straighten the grill and hood and put some tube fenders on it. I'm also going to fab up a front bumper since the stocker has obviously seen better days.
I'm thinking about ordering the BTF diy tube fender kit, has anyone ever put one of them on their jeep? It seems like a nice kit for the money.
03 TJ
Unread 09-13-2011, 09:41 PM   #14
alex211
Anyone know where I can get a new cooling fan? Mine got bent when it hit the rad. All I can find is a new fan clutch and mine works fine.
03 TJ
Unread 09-20-2011, 02:03 PM   #15
alex211
I got the grille straight and a new rad in, I'm ordering two replacement fenders for it this week, I traded the original wheels, tires, and left fender for a set of tube fenders. I'm not going to use the tube fenders because they don't have enough tire coverage in PA. Anyone know where I can get a set of front rubicon flares for it or does anyone have any they want to get rid of?
03 TJ
