My roll bar mounted side mirror - Page 2 - JeepForum.com
post #16 of 17 Old 02-27-2013, 02:11 PM
RioRyan
Originally Posted by Neil F. View Post
I did similar with a muffler clamp. I forgot what size it is but it is smaller than the above. I had to cut some of the part that slides on the U bolt and some of the padding. Anyway, mine is facing around 7 o'clock. The muffler clamp fits with the door surround on. All I need to do is remove is unscrew the mirror or twist it in to install the doors.
That sounds perfect! Any pics?
RioRyan is offline
post #17 of 17 Old 02-28-2013, 08:29 AM
Neil F.
No and I am away from home for a few more weeks. If I remember when I get back. But I don't remember what size muffler clam it was anyway. I got one that was big enough to fit over the roll bar but the thread on the U bolt were not long enough so as I indicated I cut of the bracket. To screw in the mirrior, a hex nut fit perfectly between the walls of the slider. I drilled a hole and JB Welded the nut in there. I'm using a motorcycle mirror (It's an iron cross. More for style than function but it is useable.)
Neil F. is offline
tj , wrangler , mirror , side , mount , rollcage
Can the Goodyear Kevlar's be mounted on either side? jagarcia82 YJ Wrangler Technical Forum 5 05-14-2010 03:39 PM
OBA Tanks Mounted to Roll Bar Pics NorCalCon TJ Wrangler Technical Forum 5 04-23-2010 07:45 PM
Moved mirror to roll cage - Pics... GIJOE TJ Wrangler Technical Forum 8 03-05-2007 04:12 PM
Spare mounted on roll bar frostylemon YJ Wrangler Technical Forum 1 05-21-2006 09:39 PM
where can i get some of those lights i see mounted on each side of the windshield?? incubus2012 TJ Wrangler Technical Forum 2 03-18-2004 08:33 PM
