My RMS or Not? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My RMS or Not?
Only 2 Days left to win $3,800 Jeep Parts!Security Deck EnclosureSPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 01-22-2015, 03:48 PM   #1
jdg80129
Newbie
My RMS or Not?
I have a '99 Sahara 4.0 and it was dripping from the backside of the oil pan so being the inline 6 I instantly diagnosed the rear main seal. I have since replaced it but it has started leaking at the same spot again. Could it be anything beside the rear main?
jdg80129 is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 03:58 PM   #2
TJ4Jim
Very common for the rocker cover bolts to be loose allowing oil to drip down the backside of the block winding up with a drip in the exact same spot as the RMS
TJ4Jim is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 03:58 PM   #3
biffgnar
biffgnar's Avatar
Check the valve cover back by the firewall.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 01-23-2015, 06:46 AM   #4
mdm
Farm Wheeler
Oil spilled when removing the oil filter can also end up there if not cleaned up.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 01-23-2015, 06:56 AM   #5
bobthecatkiller
Not just that but also the oil filter adaptor o rings are notorious for leaking which again goes down the block to the back side of the oil pan giving the impression its the RMS leaking.
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is online now   Reply With Quote Quick reply to this message
Unread 01-23-2015, 09:42 AM   #6
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Very common to not seal properly and leak again.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
2000' WJ Limited 4.7L-V8/D44/Quadra-Drive/31" MT's/3" lift
TheBoogieman is offline   Reply With Quote Quick reply to this message
