My RC 3.25" lift install (Pics and tips)
#46 | |
With even up to a 4" suspension lift I have known people to run a t-case drop and 1" MML with a viable angle for the rear drive shaft to not be considered "temporary". Also it may not be considered necessary to get an adjustable track bar, or relocate the current front track bar to get a "good alignment" but with an axle even slightly offset to one side you could be tortured with unexpected vehicle reactions, and also not tracking down the road straight despite the alignment. Me personally I am looking into a phased lift with the 3.25" RC lift being the first step and the 1" body mount lift by Prothane being second, followed last by a MML which could give up to 4.25" of lift and still save some money while getting more articulation. What are the opinions of everyone with the RC lift? do you like it? Just trying to decide between that and the 4" Skyjacker lift
#47 |
I'm in the middle of the install for this kit right now, looks good so far, almost done with the front!!!
#48 |
how's it looking? we need pics!
#49 |
Demonic Jeep Freak!
RC 3.25" lift with extra spacer up front on 35's.My 6th lift install.3 hours with no problems.
#50 | |
Check my build thread in my sig. I've been running this lift for several months. It's hardly settled any at all, and performs great off road. Edit: I've had the lift since march, and the mileage is around 8k miles. To the OP, did you redrill the front trackbar bracket ? Mine did not need it.
2004 TJ Rubicon........My build thread, My URE Vid www.vanc4x4.net All Who Drive Jeeps Are Not Jeepers - Willy 3:16 Last edited by RUBtjICON; 10-19-2009 at 01:40 PM.. |
#51 |
220 221 whatever it takes
Thanks for the review. I'm looking to swap out the mystery lift that came on my jeep and thiis one looks like it will work great.
#52 |
hey, can anyone tell me if their front springs look anything like this or if I have some kind of a problem. the part that holds the bump stop doesnt look like it ligns up right with the spring. I know, I dont have bump stops in because they were in horrible shape and since i dont off road any, i shouldnt have any problems. It looks like the springs are in a bind causing them to have a bow in them. I cant figure out what is causing it or how to fix this or if its normal. the pics were taken on flat ground and both sides look the same.
Thanks Todd ![]() ![]() ![]()
THE LINK TO MY REBUILD |
#53 |
Give it time to settle in.
2004 TJ Rubicon........My build thread, My URE Vid www.vanc4x4.net All Who Drive Jeeps Are Not Jeepers - Willy 3:16 |
#54 | |
Also, If you have it apart to add bumpstops, I'd swap the isolator and spring spacer as the factory isolator will hold up better to the spring than the spacer. The spacer can sometimes become distorted by the spring. |
#55 |
Also if the coil being like that really makes you uncomfortable you can always buy adjustable lower arms to determine the pinion angle and also realign the sprinch mount on the axle to the spring cup on the frame. Just food for thought.
#56 | |
#57 | |
Thanks Todd
#58 |
How is everyone's lifted rides holding up so far?
#59 |
love mine! does great on trail rides and some pretty gnarly stuff so far...I'll let you know when I get into some harder situations
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards My Build Thread [_l_,[____], l----L - OlllllllO- (o)_) (o)_)--)_) Wife≥Jeep>GF Relearn your priorities. WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift. |
#60 |
Orderd this kit today. Cant wait to get it in. Im 16 and have never put a lift in before...first jeep. Should I have it done by a pro, or put it in with a friend..?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
