My RC 3.25" lift install (Pics and tips)
#16 | |
Looks good!
In the future and if you decide to add the spacer in the back, it will be WAY easier to get your spring out if you take out the rubber bumpstop and unbolt the bumpstop cup. You would probably not have needed spring compressors to get them in if the bumpstops had been removed.
GM 350 Powered 1984 CJ-7 |
#17 | |
Sorry...I don't mean to hijack!
____ (OlllllO) 65th Anniversary Edition TJ Jeep Green Rough Country 3.25" Suspension Lift JKS 1.25" Body Lift & 1" Budget Motor Mount Lift 33x12.50/15 BFG All-Terrain's on 15x8 ProComp Series 51 w/ 3.75" BS
#18 |
With 3.25" of lift it's not possible for your front axle to be centered without addressing the front track bar in some way. Even with a 2" BB your front axle will be off.
Visit My Homepage! |
#19 |
Just take a look and compare how far your tires are sticking out from the flares on each side. You'll be able to see a difference with the naked eye.
#20 |
About taking out the bump stops, how do those come out? I thought about it but honestly couldn't see a way. I'm guessing that there's a torx that runs in the middle of the bumpstop?
I could definitely see not having to use a compressor on the front springs with the bump stops out. That would give lots of extra room. ![]() |
#21 |
looks great..
just my 2 cents but i like a slightly higher look in the front. i plan on doing my tj setup just the way you have yours now. instead of redrilling mount i would get an adjustable front track bar. just in case you go bigger later.. |
#22 | |
#23 | |
Thanks for posting the pic. |
#24 |
The bumpstops just press into the cup and the cup is bolted in. It helps to grease em up a bit when putting the bumpstops back in. When you get bumpstop extensions, at least for the rear, you will get a spacer and a longer bolt to bolt the cup back in. Some of the front bumpstop extension (like my RE ones) just bolt a spacer to the bottom spring perch.
#25 |
Thanks for this thread... this is the lift I'm getting.
[QUOTE=JerseyBowie;6865497]Lady Jeepers are hotter than mortal women, but perhaps a bit less pinkish![/QUOTE] [COLOR="Sienna"][SIZE="4"][FONT="Comic Sans MS"][B][I]Jeep Girls Do It In The Mud![/I][/B][/SIZE][/FONT][/COLOR] |
#26 |
bump for OP's flex shots
Black 98 TJ Low Output 4 Cylinder Jeep Club #178 build thread: http://www.jeepforum.com/forum/f22/mc_nickps-black-tj-build-1036334/#post9499802 |
#27 |
Vendor
Jeep looks great and sits really level too.
Call me (Jeffery) for any Rough Country lift kit issues or purchases on your lift kit. All jeepforum.com members will recieve 10% off when purchasing through me. 1-800-222-7023 ext 125 Youtube channel http://www.youtube.com/user/RoughCountryTV?feature=mhee |
#28 |
nice job... I didnt see you say, so I will ask:
1. did you just use the T - Case drop kit and no CV/SYE? 2. does it ride as good as stock (vibration or bump steer)? 3. is it truly 3.5 inches higher than it was? 4. did you get the 2.2 shocks or are they the nitro ones (I here the 2.2 shocks are a lot nicer on the raod). I am thinking of getting the 4 inch X series: http://www.roughcountry.com/jeep_tj_4x.html I am almost afraid because my jeep rides so good... I want to keep the same ride quality. nice work, your jeep looks great. |
#29 | |
#30 |
I was told the same for the SYE however I was also told it’s OK to use the T Case drop for a short period till I could get the CV/SYE.... still looking for feedback there. I plan on getting the kit and looking for a used CV/SYE kit to install... I figure should be like half price or so?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
