My RC 3.25" lift install (Pics and tips) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My RC 3.25" lift install (Pics and tips)
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 03-21-2009, 11:59 AM   #1
TJ311
So, I finally got my lift in. It's the Rough Country 3.25" suspension lift (no body lift). I did the install almost completely by myself. I started at about 9am and finally got it knocked out by about 4pm. Whoever stated in the instructions that it could be completed in 2-3 hours, I wanna see that!!
I started off with the front which went fairly well once I really compressed the new front springs. As a tip, GET A SPRING COMPRESSOR. The old springs didn't require the compressor but did require my buddy to push down on the axle while I pulled the spring out. When putting the new springs in, make sure both front springs are out and jack up the opposite side from what you're working on. This will drop down the other side as far as it will go. Compress the spring almost as much as you can and then it will go in. The rear springs were really easy.......once I removed the rear track bar. Definitely do that first thing. It will make getting the old springs out much easier. Speaking of the rear track bar; when you put the new bracket in and drill your holes, the smaller bolts were supposed to through the holes top to bottom. With the front most bolt, I had to put it in upside down with the nut on top. It was the only way to get both washers and the nut on.
The lift in all wasn't bad and could easily be done in a day. I think maybe I got lucky though and had NO rusted bolts at all. The ride is fantastic. The ride is better than stock, handles great and does allow you to feel some bumps in the road which I personally like. I did not have to use the transfer case drop kit. I drove it afterwards and it only has very slight vibrations under acceleration so I decided against the TC drop. Your mileage may vary.
Now, here's some pictures.
Before
The new springs are definitely longer!
Pry bar to push down on.
I got to work in the presence of this YJ too!
Driver's side in.
Rear track bar bracket.
After
Very level without using rear isolators.
From the front. New steering stab in there too.
TJ311 is offline   Reply With Quote
Unread 03-21-2009, 12:01 PM   #2
jimaug87
Before
Driver's side in.
After
click free
2005, I6, 6 Speed, RC 2.5", RC front adj. track bar, 31" Goodyear DuraTracs
"Nobody is comepletly useless. We can always serve as a bad example."
jimaug87 is offline   Reply With Quote
Unread 03-21-2009, 12:02 PM   #3
brooksjeep
EDIT: Beaten to it
Before
Driver's side in.
After
no clicky......
1999 TJ SE 2.5L- DD, and Weekend Warrior
brooksjeep is offline   Reply With Quote
Unread 03-21-2009, 12:41 PM   #4
Yelladog1
Can you run 33's with that lift?
Yelladog1 is offline   Reply With Quote
Unread 03-21-2009, 01:01 PM   #5
Airdoc
When you say without using rear isolators, I'm guessing this means you did not use the rear 3/4" spacers?
97 TJ, 88 M3, 95 M3, 96 328I Track Car, 00 F150 and a 04 HD Road King Custom (Buy me!!) - Thinning the herd to focus...heheh
Airdoc is offline   Reply With Quote
Unread 03-21-2009, 01:20 PM   #6
happymudder10
Very nice......
I'll give you a few months and I'll ask you again to see how it's holding up since I've been really considering one of these lifts over OME.
Just a traveling cat in a tall black hat riding a goat. Nothing to see here.
happymudder10 is offline   Reply With Quote
Unread 03-21-2009, 01:47 PM   #7
WillysEdition04
I'm gonna add this to the Upgrades section of my TJ Tech Boot Camp thread.
04 TJ Willys Edition 41MB-04TJ ...SOLD
08 JK Unlimited S.U.R.V. (SubUrban Response Vehicle)
ChevTac Firearms, LLC
"Like" us on Facebook: facebook.com/ChevTec
WillysEdition04 is offline   Reply With Quote
Unread 03-21-2009, 05:01 PM   #8
RogueSpear2023
Are those 31s or 33s, they look pretty big for 31s?
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Unread 03-21-2009, 05:15 PM   #9
TJ311
The tires are 33x12.50-15 BFG AT's. They clear great. I would highly recommend getting some 2" extended bump stops though (which I have yet to do).
True.
I just took it up the canyon today and it rode great. Handled very well around corners, on washboard roads, etc.
Here's my dog holding my Jeep from rolling.
And my girl and her YJ.
And thanks for the no clicky!
Unread 03-21-2009, 05:28 PM   #10
mudb8
want it rite or rite now?
mudb8's Avatar
True.
mudb8 is offline   Reply With Quote
Unread 03-21-2009, 06:10 PM   #11
marylandjeeper
Lookin good! Those springs look like they are progressive rate, right?
marylandjeeper is offline   Reply With Quote
Unread 03-21-2009, 06:37 PM   #12
jrb470
Looks Good!
I have the same lift only with a 1.25 BL and 1"MML.
I DID add the TC Drop kit.
I did NOT relocate my front track bar.
Did u relocate the front track bar???
____
(OlllllO)
65th Anniversary Edition TJ
Jeep Green
Rough Country 3.25" Suspension Lift
JKS 1.25" Body Lift & 1" Budget Motor Mount Lift
33x12.50/15 BFG All-Terrain's on 15x8 ProComp Series 51 w/ 3.75" BS
jrb470 is offline   Reply With Quote
Unread 03-21-2009, 07:10 PM   #13
thejafe
Well done!
Not a big deal, but I see that you put the 3/4" spacer between the spring and stock isolator. When I install 3/4" spacers I like to have the stock isolator in contact with the spring. Just a personal preference.
I've seen 3/4" spacers warp pretty badly in the rear. Over time those springs just push up into the spacer and cause all sorts of distortion.
Here's how I like to set it up in the front:
thejafe is offline   Reply With Quote
Unread 03-21-2009, 07:12 PM   #14
thejafe
Originally Posted by jrb470 View Post
Looks Good!
Your front axle IS shifted over to the driver side with that much lift. You will need to run an adjustable track bar to re-center it.
Unread 03-21-2009, 10:05 PM   #15
TJ311
I forgot to add that but I DID NOT relocate the track bar. I wanted to see where it was at first and it was still in the same place after the lift.
I see your point there. It does look better with the spacer up top. I'm thinking about actually adding in the rear spacer. The more I look at it, the more it looks like the front is higher than the back.
Anybody else experience that?
