My new Rockrail/Steps - JeepForum.com
post #1 of 20 Old 05-10-2006, 01:30 PM Thread Starter
blackjeeprubi
I ordered these the other night. My wife wanted some form of step. Do you guys think these will work well on my 2006 Jeep Wrangler Unlimited Rubicon?
http://www.quadratec.com/products/12053_4XX_PG.htm
Wes
blackjeeprubi is offline
post #2 of 20 Old 05-10-2006, 01:33 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Yea, it looks like they'll work well.
Really the only downside I see to them is the clearance loss.
Other than that, I like them. They look nice.
Wheelin98TJ is offline
post #3 of 20 Old 05-10-2006, 01:34 PM
keoki04
keoki04's Avatar
I think they will work well, but you are going to loose some ground clearance. I can vouge for Shrockworks makes great sliders and you do not loose the ground clearance. Plus they are a little cheaper. Just my two cents. But congratulations!
Current Ride:
97 TJ Sport 5spd
Check profile to see the mods!
Other mods to come...
Clicky
Clicky
keoki04 is offline
post #4 of 20 Old 05-10-2006, 01:46 PM
newjeeperguy
For less then that you could have got the Jeeperman ones.
But those look like they should do you just fine.
newjeeperguy is offline
post #5 of 20 Old 05-10-2006, 01:51 PM Thread Starter
blackjeeprubi
Thanks guys, just wanted to make sure I hadn't made a bad choice.
Wes
post #6 of 20 Old 05-10-2006, 02:03 PM
yellj
Wes
Aren't you going about this a little backwards, research first, then buy
You might have an issue with the way they mount , use the search, but if the only mounting point is the body mount points you are going to have issues with the distribution of force if you hit them hard. If it is more just for looks and steps no worries. Another vote for Shrockworks.
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
yellj is offline
post #7 of 20 Old 05-10-2006, 02:25 PM Thread Starter
blackjeeprubi
I'm pretty sure they mount to the frame. Some sites say "body mounts" and some say "chassis mount." I will know tonight, they should be deliever by the time I get home from work. If they mount to the body I may have to break out the old welder and make me some brakets to mount them to the frame. From the looks of them I don't see how they could mount to the body. They look to heavy to be hanging from the side of the body.
Wes
post #8 of 20 Old 05-10-2006, 03:25 PM
yellj
Many attach to the side of the body and through the floor of the tub with backing plates to spread the impact over a larger area, it wasn't clear, kind of described it as the type that sandwiched between the body mounts. FWIW might want to consider a gasket that attaches to your rocker so you don't have metal on metal, some seal with silicone, my preference is the gasket, used the one from Tough Stuff, good product, good luck. http://www.toughstuffproducts.com/je...ker_guard.html
yellj is offline
post #9 of 20 Old 05-10-2006, 03:40 PM
Joe-Joe
How is he going to lose clearance? They mount to the frame and are above the frame. this makes no sense.
99 TJ 2.5L 4" Currie Springs, 1"BL, 1"MML,4.0 Throttle Body, TBS, BDS ADJ Trackbar, Mopar Electric Fan, LED taillights, B&M Short Throw Shifter, 4.88's, Detroit Trutrac's front and rear, Yukon Axle Shafts, 33x12.50 Kuhmo Venture MT's on 15x8 Black Steelies
Joe-Joe is offline
post #10 of 20 Old 05-10-2006, 03:57 PM
keoki04
keoki04's Avatar
B/c they are attaching to the frame and hang below the rocker panel. Where as the shrockworks mount to the body (rocker panel). Yes, the frame hangs lower, but those rock sliders can still get hung up easily compared to the body mounted rock sliders.
Current Ride:
97 TJ Sport 5spd
Clicky
Clicky
keoki04 is offline
post #11 of 20 Old 05-10-2006, 04:24 PM
dennisuello
dennisuello's Avatar
i hit the rockerers more often that the frame.
dennisuello is offline
post #12 of 20 Old 05-10-2006, 04:41 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I have the Jeeperman Slider bars. They are awesome, As for the loss of ground clearance... it is worth it. You will be able to drive over things with out worrying about messing up the body
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #13 of 20 Old 05-15-2006, 03:08 AM
JeepRockSliders
Rock Sliders for TJ
Hey Guys. I am making rock sliders. I even started JeepRockSliders.com. Check it out.
JeepRockSliders is offline
post #14 of 20 Old 05-15-2006, 03:22 AM
175MM BULLDOG
175MM BULLDOG's Avatar
A to Z for me
Gun control: "The ability to hit your target"
175MM BULLDOG is offline
post #15 of 20 Old 05-15-2006, 09:55 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Good discussion. I am glad to see the Shrockworks ones given thumbs up as I am pretty sure they will be replacing the nerf bars on my TJ soon.
Whybu1 is offline
TJ steps on YJ? MrLude1 YJ Wrangler Technical Forum 2 11-12-2009 03:15 PM
Oem Steps On Tj That Came Without Steps mickmastermike TJ Wrangler Technical Forum 22 05-29-2009 03:42 PM
tj steps on a yj oompaloompasc3 YJ Wrangler Technical Forum 16 02-15-2009 04:34 PM
yj tj steps are they the same? skier518 TJ Wrangler Technical Forum 2 01-26-2007 10:12 AM
Steps on a 97 rustypjr TJ Wrangler Technical Forum 3 10-05-2006 11:08 AM
