My KC flood lights won't shut off? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My KC flood lights won't shut off?
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiWarn, Smitybilt, Engo, Rugged Ridge Winches at CCORIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-24-2010, 09:43 AM   #16
breckboarder55
Originally Posted by freeskier93 View Post
That's for a rocker switch. The OP all ready said it is wired into the factory harness so the multifunction switch is controlling the lights. Just clearing that up so the OP doesn't get confused.
Oh, I definitely missed that. No idea how much money that will cost.
Sorry
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2010, 09:48 AM   #17
Jerry Bransford
Administrator
Jerry Bransford's Avatar
So you removed the factory fog lights and connected the KC lights to the old fog light wiring up front?
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 07-24-2010, 09:51 AM   #18
RedHotChiliDog
yep
RedHotChiliDog is offline   Reply With Quote Quick reply to this message
Unread 07-24-2010, 09:58 AM   #19
Jerry Bransford
Administrator
Originally Posted by RedHotChiliDog View Post
yep
That pretty well backs up the above advice that you need to replace the MFF (turn signal) switch. That you can get the KC lights to momentarily shut off by moving the MFF switch very likely means the relay is ok and that its contacts are not welded shut as can happen.
Getting Savvy...
kc , flood light , electric , electrical , turn off , shut off , malfunction
