My jeep won't start!! HELP!!!! - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My jeep won't start!! HELP!!!!
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-14-2010, 11:59 AM   #16
AER2007
Originally Posted by BeachDriver View Post
My Jeep wouldn't turn over recently and battery tested good and I replaced starter and it all turned out to be a bad batttery.
Here is my recent thread about it...Don't know if it will help you but thought I would post it as I thought my battery was good as it tested ok but it was bad.
http://www.jeepforum.com/forum/f12/9...-good-1053281/
I read thaqt thread, and I would be willing to bet that your friend did not test the battery properly.
You said he load tested it. Chances are he used a hand held toaster oven style tester, which puts 60-70 amps on at best. You cannot properly load test a battery unless you apply half the CCA. I have dealt with many mechanics who did just that, and showed them that their battery was bad even though their tester said it was good
[QUOTE=mrblaine;8824148]You're starting to be beyond pedantic and that's my job, quit trying to take it from me. [/QUOTE]
[QUOTE=ageorgakis;8342820]No, I wasn't being comical. I'm being perfectly honest. I don't have any dyno tests. But you can FEEL the difference![/QUOTE]
AER2007 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2010, 06:55 PM   #17
ckid222
I also had a problem like this and it was my ignition coil. Replaced it and it was all good.
ckid222 is offline   Reply With Quote Quick reply to this message
Unread 10-07-2010, 11:35 AM   #18
jamesrw30
I have since had the battery tested at Advanced and it showed good. I was checking the connections at the starter and found that when I turn the key I do not get voltage to the small post. I have been told that is probably a fuseable link in the ignition to the starter. My nest question is how in the world do I locate this? I havent the slightest idea where it is. :-/
jamesrw30 is offline   Reply With Quote Quick reply to this message
Unread 10-07-2010, 12:05 PM   #19
AER2007
Follow that wire back until you have power, and that will tell you where you are losing it. It could also be the switch on the clutch.
Unread 10-07-2010, 12:24 PM   #20
jamesrw30
I have bypassed the clutch safety switch and it didn't help. I am hoping to get a day soon to start tracing that wire down and hopefully find the problem.
tj , wrangler , won't start , issues , problems
