My jeep won't start!! HELP!!!! - Page 2 - JeepForum.com
post #16 of 20 Old 07-14-2010, 10:59 AM
AER2007
Originally Posted by BeachDriver View Post
My Jeep wouldn't turn over recently and battery tested good and I replaced starter and it all turned out to be a bad batttery.
Here is my recent thread about it...Don't know if it will help you but thought I would post it as I thought my battery was good as it tested ok but it was bad.
http://www.jeepforum.com/forum/f12/9...-good-1053281/
I read thaqt thread, and I would be willing to bet that your friend did not test the battery properly.
You said he load tested it. Chances are he used a hand held toaster oven style tester, which puts 60-70 amps on at best. You cannot properly load test a battery unless you apply half the CCA. I have dealt with many mechanics who did just that, and showed them that their battery was bad even though their tester said it was good
You're starting to be beyond pedantic and that's my job, quit trying to take it from me.
Originally Posted by ageorgakis View Post
No, I wasn't being comical. I'm being perfectly honest. I don't have any dyno tests. But you can FEEL the difference!
AER2007 is offline
post #17 of 20 Old 07-14-2010, 05:55 PM
ckid222
I also had a problem like this and it was my ignition coil. Replaced it and it was all good.
ckid222 is offline
post #18 of 20 Old 10-07-2010, 10:35 AM Thread Starter
jamesrw30
I have since had the battery tested at Advanced and it showed good. I was checking the connections at the starter and found that when I turn the key I do not get voltage to the small post. I have been told that is probably a fuseable link in the ignition to the starter. My nest question is how in the world do I locate this? I havent the slightest idea where it is. :-/
jamesrw30 is offline
post #19 of 20 Old 10-07-2010, 11:05 AM
AER2007
Follow that wire back until you have power, and that will tell you where you are losing it. It could also be the switch on the clutch.
AER2007 is offline
post #20 of 20 Old 10-07-2010, 11:24 AM Thread Starter
jamesrw30
I have bypassed the clutch safety switch and it didn't help. I am hoping to get a day soon to start tracing that wire down and hopefully find the problem.
tj , wrangler , won't start , issues , problems
Jeep won't start - Starter doesn't start cooltc2004 YJ Wrangler Technical Forum 5 12-29-2008 10:36 AM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 08:28 AM
Wipers start when I start the jeep Rock & Roll TJ Wrangler Technical Forum 3 09-07-2005 10:12 PM
Time to start thinking of getting rid of the Jeep...need help pricing out my Jeep... ///M Coupe YJ Wrangler Technical Forum 14 01-06-2005 05:41 PM
