My Jeep is Possessed - HELP! - JeepForum.com
post #1 of 7 Old 03-24-2009, 06:26 PM Thread Starter
w8r
It was raining here this evening and when I turned my lights on I noticed my right turn signal indicator was on steady (not blinking) but my turn signal wasn't on. I turned on my left signal and it worked but the right signal indcator stayed on (steady without blinking). I turned on my right signal and the outside signal blinked but the indicator stayed on (w/o blinking).
I turned my lights off and the left signal worked fine. However, when I tried to use my right turn signal, the signal didn't work but my dash lights flashed on and off.
What's up with THAT?!?
w8r is offline
post #2 of 7 Old 03-24-2009, 07:15 PM
ET48
What do guys think? Time to change the clockspring?
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #3 of 7 Old 03-24-2009, 07:24 PM
XXRider
Clock spring or turn signal switch
A must-read for new TJ owners/forum members
XXRider is offline
post #4 of 7 Old 03-24-2009, 07:27 PM
Dmcastino
Before you go throwing parts at it, I would give it a few days to dry out first. I leave my doors/windows off the entire summer and occasionally my turn signals do goofy things for a few days after it rains, but they eventually dry out and go back to normal
Dmcastino is offline
post #5 of 7 Old 03-24-2009, 07:30 PM
SYN ACK
SYN ACK's Avatar
I had some issues with possessed driving lights and waited it out. Everything dried and they're back to normal.
I also have issues with the check engine light coming on after a really hard rain. Dries out and it's fine again. *shrug*
Are you new? Own a TJ? Want a TJ?
Everything you need to know is here:
SYN ACK is offline
post #6 of 7 Old 03-24-2009, 07:33 PM
banyanmage
Leave it alone for a week to dry first and if there are still issues then I'd push for the clock spring. I've had a few weird things like that go away after a couple dry days.
banyanmage is offline
post #7 of 7 Old 03-25-2009, 11:58 AM Thread Starter
w8r
It stopped raining last night. This morning the problem disappeared. Evidently it was moisture in the clock spring - whatever that is.
THANKS FOR YOUR HELP!!!
w8r is offline
Possessed Jeep.....TIPM issue?? Lights, horn wipers, etc.... Busa196 JK Wrangler Technical Forum 40 12-31-2015 06:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Heater is possessed. ncarnahan TJ Wrangler Technical Forum 0 01-29-2008 05:33 PM
My Jeep is Possessed.. Heeeelp! :) denwagh YJ Wrangler Technical Forum 4 05-08-2007 03:02 PM
LJ is possessed!!!!!!!!! None TJ Wrangler Technical Forum 21 03-05-2007 07:34 PM
