My Jeep has Emphysema - JeepForum.com
post #1 of 13 Old 09-28-2012, 12:52 PM Thread Starter
R-Sticker
My engine is laggin' badly. It's a 42RLE with 33" tires (285/75r16) and 4.88 R&P. I think it is dropping into OD at about 50 MPH. Once there, the RPMs sit at about 1200 on flat roads. To get a downshift, I have to put the pedal on the floor.
I just put in the 4.88s and have not put a new speedo gear in, but that should not effect the transmission. Any ideas?
R-Sticker is offline
post #2 of 13 Old 09-28-2012, 01:03 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by R-Sticker View Post
It's a 42RLE
found the problem!
if you're shifting into OD at 50mph, you're doing better than most. Typically the shift into OD w/ 4.88s and 33s is around 38 mph.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 13 Old 09-28-2012, 02:16 PM Thread Starter
R-Sticker
found the problem!
Are you saying that I should have put in 5.13s? I don't know how that would go at 80 mph.
post #4 of 13 Old 09-28-2012, 02:21 PM
Unlimited04
No, I'm saying you shouldn't have bought a 42RLE...because your experience is normal for this transmission.
Useful Write-Ups:
Funny:
post #5 of 13 Old 09-28-2012, 05:49 PM
rchase559
You would are doing approximately 35 MPH at 1200 RPM
At 50 MPH you should be at about 1700 RPM
Get the correct speedometer gear and report back to the class
rchase559 is offline
post #6 of 13 Old 09-28-2012, 06:00 PM
fromme
fromme's Avatar
1977 CJ7
Sad for me to remember but I sold my first TJ Rubicon because of this transmission. With 5:13s and 35s and trying to lighten it as much as I could, it was still a pig and drove like a pig. I hated it on the road, and I hated it on the rocks. My current TJ is a 6spd and I'm running 4.88s and 33s taching 3000 rpm at 70 and lovin every minute of it.
About the best you can do is get in the habit of reaching down and hitting the O/D cancel button every time you start it up.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #7 of 13 Old 09-28-2012, 06:14 PM Thread Starter
R-Sticker
Yes, Mr. Schoolmaster. I was waiting for someone to point that out. I need a 41-tooth speedo gear. My RPMs might be the same, but my speedometer may be... as you say... 35.
Next question: how difficult is it to swap a 42RLE to a NSG370 (or AX15 or NV3550)... ?
post #8 of 13 Old 09-28-2012, 06:17 PM
JBTJ
Bottom line is the 42rle is a piece of !!!! No matter what you do to it it's still a 42rle. Kind of like the D35, which is better. But still a piece of !!!! Sorry guys.
JBTJ is offline
post #9 of 13 Old 09-28-2012, 06:32 PM
rchase559
I'm pretty sure the PCM/TCM takes vehicle speed into account when it determines when to shift.
I think the wiring on yours is a bit different but on my 2003 the wiring for the transmission is heavily integrated into the rest of the wiring harness. There doesn't appear to be any disconnects to easily remove the transmission wiring.
post #10 of 13 Old 09-29-2012, 05:20 AM
4banged
I don't think the speedo change will effect shifting...I know it didn't on my 03 going from stock 28's to 31's. Theres a speed output sensor on the tranny that the tcm/pcm uses in its moronic shift formula. The speedo is only for your gauge from what I've read. You need to start a close relationship with your OD button...hit it any time you get on highway and get it up to 65 before hitting again. Welcome to the 42rle fan club!
My biggest complaint is it doesn't release the torque converter clutch under load in OD like it does in 3rd. I have no idea why it was programmed like this.
4banged is offline
post #11 of 13 Old 09-29-2012, 05:41 AM Thread Starter
R-Sticker
Yea, it looks like I'll be switching off the O/D at start-up (and turning it back on when I hit the highway).
I need to save my ducats for a V8....
post #12 of 13 Old 09-29-2012, 09:11 AM
rchase559
My 42RLE doesn't seem to shift into OD and lock up TC until 45 no matter how far off my speedometer is. In my experience it does have some bearing on the shift points. Even when going from 30's to 33's and then 33's to 35's while still on 3.73s.
Tapping the brakes just enough to turn the lights on will unlock the TC. Yes its annoying but this combined with learning how and when to use the OD off button will make the transmission more usable IMO.
post #13 of 13 Old 09-29-2012, 09:53 AM
77351wcj5
If you look at a gear calculator for the .69 overdrive ratio, you may determine that a 5.13 gear would be too high.
5.38's @ 3,000 rpm would give you 80 mph, 120mph @ 4500 rpm - given you have the horsepower to pull that speed.
77351wcj5 is offline
engine , lag , shift points , speedo gear , transmission
Jeep TJ Wrangler 1997 -2004 ,V-6 Conversion Package , Retaining the Stock Jeep 5?? Travisray91 TJ Wrangler Technical Forum 12 10-05-2011 12:50 PM
Pulled a Fellow Jeep out in wading Riverlong island..anyones jeep? LITJGuy Wrangler General Discussion 72 12-16-2010 09:31 AM
Got jeep back from shop, coolant level low, jeep running cold. kainers YJ Wrangler Technical Forum 4 10-30-2010 07:51 PM
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
