My HEMI build thread - chronicles of a NOOB. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My HEMI build thread - chronicles of a NOOB.
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-21-2010, 05:41 AM   #16
crusher242
^^^ Good question about the ABS. I've been wanting to ditch my unit for years now.
Hold onto something... Quick!!!
crusher242 is offline   Reply With Quote
Unread 12-21-2010, 05:58 AM   #17
hustler905
I believe the black plastic box under the battery is somehow connected to the vent selector. Mine wouldn't switch vent modes well at all, and when I did a fender replacement I fixed a split in what looked like a vacuum line to that little box and now it switches vents great.
hustler905 is offline   Reply With Quote
Unread 12-21-2010, 06:23 AM   #18
07wurubi
07wurubi's Avatar
Same here. I priced out the replacement lines from the dealer and it was close to $200 for the lines and proportioning valve.
Mike Fox
My Jeep:
00 Wrangler Sport 4.0L NV3550
4" RC LA full suspension system
Bilstein 5100 shocks all around
axles (30,8.8) with 4.88 gears ARB F/R
SYE and CV rear driveshaft from Drivelines NW
Currie HD steering (Thanks Savvy, Awesome customer service)
Savvy LED tail lights (Thanks again Savvy)
GY MT/R Kevlar 35x12.50x15 on 15x10 American Racing AR23
Bestop soft top with tinted windows
Smitty front and rear bumpers w/rear tire carrier
Smitty XRC8 winch w/synthetic rope
Smittybilt rear corners and 3" flares, rock sliders with step and 3" front tube fenders
Dodge Durango steering box with Pure Jeep skid and M.O.R.E. steering brace
07wurubi is offline   Reply With Quote
Unread 12-21-2010, 06:44 AM   #19
UTWeezul
Same here!
Enjoy life to the fullest each and every day!
http://www.midsouthjeeps.com/
UTWeezul is offline   Reply With Quote
Unread 12-21-2010, 06:48 AM   #20
AlexGeorgakis
AlexGeorgakis's Avatar
If I remember correctly, there are two tubes leaving the master cylinder going into the proportioning valve. From the proportioning valve there are two tubes going to the ABS unit (if I'm not mistaken). The ABS unit then splits this into 3 lines, two going to the front brakes and one going to the back. I think that if I can find two flexible high pressure hoses and a Y fitting, I can connect one outlet of the proportioning valve to the front brakes using a Y fitting, and the other outlet to the rear brakes. I'll look into it in more detail tonight.
As far as brake fluid pressure is concerned, the guy with the hemi told me that all the competition guys use the master cylinder off a Mercedez truck which pumps a lot more pressure than the stock cylinder. I'll have to do some research on this, otherwise my next purchase will be a Vanco brake kit.
AlexGeorgakis is offline   Reply With Quote
Unread 12-21-2010, 07:01 AM   #21
HemiTJ
Junior Member
HemiTJ's Avatar
I did a Hemi swap with the help of a couple of friends. It was fairly easy. (expensive, but easy). I had few bugs to work out. There is allot of support available on the internet, if you spend the time looking. Feel free to PM me if i can answer any of your questions relating to the swap.
HemiTJ is offline   Reply With Quote
Unread 12-21-2010, 07:07 AM   #22
AlexGeorgakis
Hey thanks! I just might take you up on that offer. One problem which I know I'll be facing (but I'm not there yet) is how to hook up the A/C compressor. I doubt it will fit in the stock location. Do you have a build thread which I can follow?
Unread 12-21-2010, 07:07 AM   #23
mystangt
I am jealous on 2 counts:
1 - I just spent my summer in Thesalonikki and loved it so i am jealous that you are in Greece while its been freezing up here in NY
2 - You are building exactly what i want! I just dont have the $$$ for it being that I graduated college just last Wednesday =)
καλή τύχη!
Need a hand with working on your Jeep in NY, NJ or CT area? Please visit: www.LetsJeepTogether.com
mystangt is offline   Reply With Quote
Unread 12-21-2010, 07:19 AM   #24
AlexGeorgakis
καλή τύχη!
Thanks! Thesaloniki is beautiful. Congrats on the graduation. That's the first step to saving up cash!
Unread 12-21-2010, 07:21 AM   #25
AlexGeorgakis
Just looked at the FSM. I was right. I just don't have to go through all the trouble to modify this with aftermarket parts. I just need to find a TJ without ABS and get the necessary parts.
Unread 12-21-2010, 07:54 AM   #26
jeep2008
Good luck!!!!!!!Subscribed!
PSo you plan on selling the I6?
my build thread
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline   Reply With Quote
Unread 12-21-2010, 08:54 AM   #27
Lawrence
If you have a couple of questions, you may want to jump on Expedition Portal and contact forum member OS-Aussie, he had a TJ with a Grand Cherokee 5.7L. Chris & Tony Squire @ Hotwire Auto can also give you some good advice. Check out their gallery for some good pics, especially Chris' TJ (the white one).
If you don't have the time to do it right, what makes you think you'll have the time to do it twice?
Lawrence is offline   Reply With Quote
Unread 12-21-2010, 09:26 AM   #28
AlexGeorgakis
Ahhh I sold it already. I do have a 32RH (with the breather mod and deep sump pan) and possibly an NP231 for sale as well as some other stuff... snorkel, fenders, engine skid plate. Once I'm done with the project I'll let you know.
Thanks. Will check it out now.
Unread 12-21-2010, 10:00 AM   #29
dgi
Wish it were quieter...
dgi's Avatar
Good to see more Greek guys on the forum and doing fun builds!!! i had my 2000 TJ on Kasos Island from 2000-2004 then had to bring it back to the states since i had american tags on it... they wanted ~20K euro to transfer it to greek tags... we brought it back and bought a vw bettle but the jeep was fun cruising around on the island. Always wanted to bring it back... we'll see what happens.
dgi is offline   Reply With Quote
Unread 12-21-2010, 10:05 AM   #30
AlexGeorgakis
20K cause you didn't have the right contacts. You've seen how it is here first hand. If you're ever in the area let me know!
