My heater won't work??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My heater won't work???
The Original 3/8" Ruffstuff Diff Cover!3" BDS Suspension Lift Kit - Jeep JK 07-11Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-21-2008, 06:44 AM   #1
byrdi
my jeep is a 99 tj with a 4.0......
it recently for some reason the heat won't heat up very warm at all the engine temp is perfectly normal and it has plenty of coolant but i have noticed that the coolant looks rusty colored... somebody said it might be a thermostate???? could that be the reason my heat won't work... i'm just tryin to find out what it could be because i'm aboout the flush the radiator and i want to fix it all at the same time
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
byrdi is offline   Reply With Quote Quick reply to this message
Unread 10-21-2008, 09:30 AM   #2
byrdi
bump it up
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
Unread 10-21-2008, 09:33 AM   #3
Spike101188
Drop the coolant. Maintain that or you'll have much bigger problems. Replace the coolant and thermostat at the same time, thermos are really cheap. Maybe give your system a flush but then u risk opening up and holes in your radiator that are currently clogged up. I would try flushing the system though... sounds like there is air in your system.
Spike101188 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2008, 09:37 AM   #4
byrdi
what is the best way to flush the radiator ??? i'm going to do it myself
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
Unread 10-21-2008, 09:44 AM   #5
Spike101188
Well if the wrangler is like the cherokee its a real pain. On the cherokee the drain valve for the radiator is passenger side by the headlight. This means u have to take off the header panel//headlight assembly. You can always pop off the bottom hose leading to the water pump but that can be a pain too because of the clamp. Prestone sells a flushing kit that you can splice into your system, prone to breakage though. The few times ive flushed mine its been either for a radiator replacement or hoes breakage so i had a simple way to flush. maybe someone will have a better insight for a wrangler. The technical way to flush it is drain all the coolant through the stop **** on the rad, then fill it up with DI Water, run it for 5 mins with the heater on full blast and let the thermostat open up. Then let it cool back down, drain the DI from the stop **** and fill it back up with coolant.
Unread 10-21-2008, 09:58 AM   #6
rmellish
Get a higher temp thermostat. Problem shouldn't be the coolant.
rmellish is offline   Reply With Quote Quick reply to this message
Unread 10-21-2008, 10:19 AM   #7
byrdi
i think my thermostate is not shutting and thats why it's not heating up... i just want to change the fluid because it needs changed
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
Unread 10-22-2008, 06:38 AM   #8
byrdi
ok new thermostate and flushed the radiator and still no heat.... the upper heater core hose is really hot and the lower hose is not as hot????? what is wrong with it???
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
Unread 10-22-2008, 07:58 AM   #9
57phinney
your ther isnt opening. you have thermstate in the rite way.
57phinney is offline   Reply With Quote Quick reply to this message
Unread 10-22-2008, 08:32 AM   #10
Wif
Blocked heater core .. or air lock (unlikely).
Give it a thorough flush .. do it properly.
Get some radiator flush (Prestone), dump all the coolant that will come out the bottom rad drain, re-fill with water adding the flush liquid .. follow instructions about running the engine. Let it cool down and dump the fluid again.
Repeat with another bottle of flush (if you can afford it and can be bothered).
After the final flush, dump all the water out the botttom of the rad drain, refill with clean water and run the engine up to temp again. Let it cool and dump again. Keep doing this until the water comes out clean(ish). On the last fill, fill with pure antifreeze.
If this doesn't cure it you'll need a new heater core.
[B]----------------------
Formally 88Jeepster
----------------------[/B]
[I]Who's[/I] in front ?
Ridin' topless again .. sweet !!
Wif is offline   Reply With Quote Quick reply to this message
Unread 10-22-2008, 08:35 AM   #11
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2 on a blocked heater core.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2008, 01:08 PM   #12
byrdi
i hooked a water hose to the upper heater core hose and water came out the bottom hose so i really don't think it is the heater core...... one thing i forgot to mention is.... i drove my jeep home from work (25miles) got out and immediately opened the hood to cool off and i went to let the pressure off the radiator by loosing the cap and it had zero pressure whatsoever and i had just driving it 25 miles????? what would cause that
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
Unread 10-22-2008, 01:17 PM   #13
Wif
Sounds like two things. You have a low coolant level .. and you rad cap is leaking off pressure.
Formally 88Jeepster
Unread 02-19-2009, 06:35 PM   #14
charliekimberly
i had problems with my 2000 jeep. you need to flush the heater core backwards. hook a water hose to the top connection and then a length of hose to the bottom connection to a pan and turn the water on. let it run for about 15 minutes. You'd be surprised how much dirt comes out. The owner before me put block seal in mine and when i flushed it the first time it just clogged up the heater core.
charliekimberly is offline   Reply With Quote Quick reply to this message
Unread 02-19-2009, 07:23 PM   #15
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Did you conduct a FLUSH or just dump the old coolant? You can purchase a "FLUSH KIT" and flush chemicals from places like Walmart or your local auto parts store. You will have to cut the hose going to (or coming from) the heater core to install the flush connection. Pour in the coolant flush chemicals (into the radiator) and drive the vehicle around (as per instructions) and dump and flush the coolant system. If you have too you might have to remove the hoses from the heater core one at a time to insure that you are getting flow in the heater. NOTE: Carefully remove the hoses as not to damage the heater core. If you have good flow in the heater core the next thing to check in the thermostat. Remove it and insure you have flow thru the block. (You will be inserting water from the radiator to do this. I handle comes in your flush kit.)
If you have good flow re-install the thermostat, re-connect hoses and re-fill coolant system. Re-test the system.
You can leave the flow hose connection on the heater hose for future flushing.
Group W Bench
CRAWLING 98 is offline   Reply With Quote Quick reply to this message
