Quantcast My FLAT skid, write up by request, - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My FLAT skid, write up by request,
Old 12-11-2008, 06:06 PM   #16
RnEmOvr
Never Forget
RnEmOvr's Avatar
i will measure how much clearence i have tomorrow its dark right now, i literally just tried to see how much i had
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 12-11-2008, 06:07 PM   #17
cgmrdc
well we cant go flat with 1" or even the 1.25" jks thats on my cousins so 2" is probably just about right without the BFH mod...
cgmrdc is offline   Reply With Quote
Old 12-11-2008, 07:27 PM   #18
Scotch740
I went flat with a 1.25" BL and the 33engineering trans mount. No hammer needed. I may end up dropping it an inch for other reasons though.
Scotch740 is offline   Reply With Quote
Old 12-11-2008, 07:29 PM   #19
Trombino
What reasons, if I may ask? I've actually saved the plans from your write-up and plan on tackling that project over the Christmas break.
Trombino -- '04 TJ -- Rubicon Express 4.5" Superflex + 3/4" Front Spacers, OME Shocks, Currie Rear Shock Relocators, JKS 1.25" BL, JKS BMML, JKS Quicker Discos, 15x8 Cragar Soft 8's, 35x12.50 BFG KM's, LoD Heavy Duty Rear Tire Carrier, Chopped Front Bumper, Uniden 520XL w/ 3' Firestik II, Skyjacker Steering Box Skid, Rusty's Engine Skid, IPF H4 Conversion w/ Fatboys, Hella 500 Windshield Driving Lights, Tomken Gas Tank Skid, ARB Rock Sliders, PSC Rock Ring (D30), Riddler (D44), MV50 OBA, Rusty's Air Tube, TBS, Flowmaster 40, Dana 44 with Trac-Loc, Warn XD9000i w/ Grill Guard
The Wife -- '02 KJ Limited -- Pre-Lowered, Full Mopar Skids, 245/70-16 General Grabber AT2's, Trac-Loc Rear, Flowmaster 50 SUV
Trombino is offline   Reply With Quote
Old 12-12-2008, 12:46 AM   #20
cgmrdc
i could see being able to go flat with a diff trans mount but we retain the stock one...
Old 12-12-2008, 07:15 AM   #21
Scotch740
I would like to mount my air tank under there and I just need a tiny bit more room. I also have issues with my drive line angles after the lift went on. Had to get my drive shaft rebuilt 2 times in 4 months. Hopefully its fixed now with some additional grinding by Tom Woods. But I am sure a little less angle wouldn't hurt. Also I would like to recess my bolt heads and by dropping it an inch I can do that easily while not having to switch to a flat head bolt that takes a hex wrench. It will move my engine skid a little lower so I may be able to use a Fumoto drain valve I got but couldn't because of clearance. Finally it may help a tiny bit with the heat from the floor boards. They get really hot in the summer.
After the lift I have a little over 20" of belly pan clearance so I dont mind losing 1" as much as I did when I was stock.
Old 12-12-2008, 07:44 AM   #22
erickpl
The 33 Engineering one has been my desired belly up, esp since I have the 1.25" BL. But this homebrew may have potential. With a stock muffler, if you set this 3/4 to 1" lower from the frame I wonder if it would keep it from hanging up...
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline   Reply With Quote
Old 12-12-2008, 03:18 PM   #23
RnEmOvr
Never Forget
RnEmOvr's Avatar
well the prob is the exhaust attaches to the trans mount and to the the skid, you could prob rework exhaust hangers, ill try to get pics today while im under there
www.cityprofile.com
Old 12-12-2008, 03:39 PM   #24
silverjeep
Very cool! More please.
CHECK OUT MY LJ BUILD THREAD
silverjeep is offline   Reply With Quote
Old 12-12-2008, 03:44 PM   #25
trailhugger
Yeah i agree very cool idea with the skid plate.I wish i would of come up with that idea before i purshased a new sid row transf engine skid.
trailhugger is offline   Reply With Quote
Old 12-12-2008, 04:39 PM   #26
wrangler2007
What if the skid was the same design as the one that RE makes for their LA kits and you angled the edges slighty so that it will slide over things? You could also cut out an area for the driveshafts to go through couldn't you?
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers
wrangler2007 is offline   Reply With Quote
Old 12-12-2008, 08:04 PM   #27
RnEmOvr
Never Forget
RnEmOvr's Avatar
i could but more bending then i wanted
www.cityprofile.com
Old 04-08-2009, 09:13 PM   #28
FernBchJeep
Go ahead, try it and see.
FernBchJeep's Avatar
Nice work!! And yes, add the bracing even with a 3/8" plate. A buddy did one and warped it, had to make another, he added the bracing and it's fine.
Silence is Golden, Duct tape is Silver
Member IBEW Local 1924
40' Up, Blue Skies, and NO Net. Just Another Day At The Office!
Work with enthusiasm as though you were working for the Lord rather than for man.
http://www.treadlightly.org/
Siena Jeep Owner's Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
FernBchJeep is offline   Reply With Quote
Old 04-18-2009, 08:51 PM   #29
RnEmOvr
Never Forget
RnEmOvr's Avatar
i finally check and you could do this skid with a 1.25" BL and a little body massage to the trans tunnel
www.cityprofile.com
Old 05-15-2011, 09:10 PM   #30
fish4life
I'm reviving this old thread as I'm intrigued at the idea of a flat skid with just a 1.25" bl (plus little body pounding ).
I do not see how the transfercase is mounted to the new plate. Does anyone else see how it is done, or can the OP perhaps throw a few more lines on how the mount was achieved??
Cheers!
fish4life is offline   Reply With Quote
Glock Forum
