Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Wild Boar Products Cargo Rack or Front Bumper Giveaway
Go Back   JeepForum.com > Models > Wrangler Forums Group > TJ Technical Forum
Register FAQ Search Today's Posts Mark Forums Read Search Members
Old12-11-2008, 05:10 PM #1
RnEmOvr
You Are NOT Forgotten!
RnEmOvr's Avatar
Send a message via Yahoo to RnEmOvr
My FLAT skid, write up by request,
ok, so we all know the TJ TC (transfer case) skid hangs to low, and aftermarket skids cost alot, building your own is nice and cheap, but what to do about those bolts? get ride of em? but need to remove it still so cant weld it. here is the fix,
i went to the local metal shop and ordered a piece of steel was 54" by 24" of 1/4" plate (its a little wide cause i wanted the extra for gussets for new cage) i then took measurement in rear of frame (bout 2" behind rear bolt hole) then went 24" toward the front and took that measurement (since frame narrows) then i took these measurements and marked them on the plate and since i have access to a 112 ton press at work i had guy i work with bend it on my marks to 90 degrees, ending up with this
i then measured height of frame and location of the body mount and cut them out and trimmed skid down
then with skid in place i drilled 3 holes on each side, and added some grade 8 bolts and ended up with this
now i dont have this finished but i will added some steel tube in the holes of the frame to keep it from crushing (i will weld it but not needed, just easier to install) and for now i drilled holes in bottom of skid and trans bolts just hang below but i will end up building a cross member like this one, and i will weld some 1" angle on top edge of skid in a "^" pattern to help with bracing, hope this helps, as of now i have $110 in steel, $30 in drill bits (broke one so really only $20, and burnt one up due to no cutting oil so could be $10) and $15 in bolts/washers/nuts,
new muffler is needed since OEM hangs below skid
, and a SYE will be needed if you have ANY lift since this accounts for a 3" lift in your driveline, you will need BL as well, or a tub massage, i have 2" BL and it clears fine
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
RnEmOvr is offline   Reply With Quote
Old12-11-2008, 05:18 PM #2
wrangler2007
Think I might have one of those done! Did you need to do any exhaust mods or TC modding?
Red 02 TJ Wrangler X, 4.0L, 5-Speed, RE 4.5" SF w/ 3.5" Springs, 1" BL, 33x12.5, 4.56 Gears, Warn Front/Rear Bumpers, Advance Adapters SYE, TW CV, Bushwacker Flares, Steering Box Skid, Steering Skid, Warn xd9000i, TNT Rocker Guards w/ Step
'07 Mustang GT, Whipple 10 lbs. boost, 465 rwhp, Magnaflow, Hurst , AVIC D3 NAV/Buetooth/Ipod, Spec 3+, BMR Rear LCA/UCA, Autometer, FRPP Springs
wrangler2007 is offline   Reply With Quote
Old12-11-2008, 05:25 PM #3
RnEmOvr
RnEmOvr's Avatar
edited above to answer that since i forgot to add it
Old12-11-2008, 05:39 PM #4
cgmrdc
how much BL/Tub modification did you need to make it flat?
looks like two by the pic correct?
just kidding I cant read... wow its been a long day...
98 TJ sport... lots of misc parts...check'em out...
Project College FUNd
Custom TJ Belly-up Skid
Home Made Mini Boatsides
cgmrdc is offline   Reply With Quote
Old12-11-2008, 05:41 PM #5
dz1087
The Daily-Llama
dz1087's Avatar
Nice work - subscribed for when I start modding.
Air Force Jeep Club - Tail# JF037AD
'03 TJ Sport, Black on White, Stock. [[Gone]]
'99 XJ, Purple, Stock but with new wheels.
Running Doorless? Check your state's Mirror Laws!!
http://www.jeepforum.com/forum/f176/list-state-mirror-laws-565361/
There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else.
Theodore Roosevelt
dz1087 is offline   Reply With Quote
Old12-11-2008, 05:42 PM #6
snowcrash
snowcrash's Avatar
Thats AWESOME!! I've seen some pretty flat skids but thats one is amazing. Awesome!!
-Aaron
Member Cape Cod Jeep Club Massachusetts
2006 Silver TJ Sport D44/D30 4.88s:
RE Extreme Duty 5.5", Currie HD Steering Kit, JKS 1.25" BL, 35" MTZs, Cragar Black "D" rims, ARB Snorkel,ARB F&R lockers, Centric Premium Rotors with EBC Yellowstuff Pads, Mastercraft Rubicon Dirt Sport Seats, RE Steering Stabilizer. AtoZ rockers with step, Gen-Right Full corner guards, AtoZ tire carrier, Bushwacker Fenders, Cobra 75WXST with Red Firestick II, Riddler Diff covers front/rear, Optima yellow top, PSC Stinger, Banks Power Monster Exhaust, RockHard Cage
snowcrash is offline   Reply With Quote
Old12-11-2008, 05:42 PM #7
RnEmOvr
RnEmOvr's Avatar
i have 2" but ive had it for years so i dunno how much is realy needed
Old12-11-2008, 05:44 PM #8
wrangler2007
I've never found this answer...why is the BL needed for the TT you made?
Old12-11-2008, 05:47 PM #9
cgmrdc
thats what i thought. my cousin and I build belly ups for guys in our club but we usually only do 1" BL but our skid hangs down 1" from the frame... go figure
looks good post up when youve got the bracing done
Old12-11-2008, 05:48 PM #10
02tjsport
Send a message via AIM to 02tjsport
I wonder if a 3/8" steel would even need bracing?
[center]'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline   Reply With Quote
Old12-11-2008, 05:49 PM #11
cgmrdc
not enough room to move the tcase up much further... simple solution... make more room with a BL
Old12-11-2008, 05:50 PM #12
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Nice work.
I added a link to this thread in the FAQ.
98 TJ
02 WJ
Wheelin98TJ is offline   Reply With Quote
Old12-11-2008, 05:52 PM #13
wrangler2007
THANKS MAN!
Old12-11-2008, 06:02 PM #14
RnEmOvr
RnEmOvr's Avatar
i would say most likely, cause the 1/4 bends a lill just from jacking it up and even weight of driveline makes it sag
Originally Posted by Wheelin98TJ View Post
Nice work.
sweet my life goal has been met, being usefull to JF!!!!
Old12-11-2008, 06:05 PM #15
wrangler2007
What do you think is the minimun necessary clearance with the body? I'm thinking about either just going ahead and pounding or either getting a BL and cutting it into a smaller piece and using shorter bolts or something like that?
Ebay flat fender write up, RnEmOvr TJ Technical Forum 13 08-14-2008 04:14 PM
Pic request of Skid Row Engine/Trans skid on 4DR Rubicon koheed JK Technical Forum 0 04-18-2008 09:58 PM
Flat skid to replace shovel stock skid? 92yj97xj TJ Technical Forum 38 01-11-2008 07:53 PM
YJ homecut flat fender *PICTURE REQUEST* Roach YJ Technical Forum 9 08-10-2006 04:32 PM
Need Skid Row Engine Skid Installations Write-up harleysilo TJ Technical Forum 2 03-13-2006 02:43 PM
The time now is 02:42 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
