My first Jeep - Page 2 - JeepForum.com
post #16 of 39 Old 06-30-2013, 04:13 PM
KansasCityTJ
Originally Posted by AmnSyd
So it it actually a 4 cylinder? It does make a difference when it comes time to put 35's on it.
What difference does it make? ( i am going to increase hp with engine mods.)
KansasCityTJ is offline
post #17 of 39 Old 06-30-2013, 04:21 PM
06philaTJ
Originally Posted by IanBakes View Post
Thanks Everyone! The only problem is that i have to drive about a hour and 1/2 to get to the dealership, so its more of a one and done thing. if it drives well and i get under the vehicle and there is minimal rust ill offer around 7000. What will rust do to the vehicle overtime, and is there anything i can do about it?
Most likely based on the low mileage, it sat alot at one point. TJ's are notorious for water leaks, especially with soft tops, and it seems like that one has had water fill up the floors a few times, which is why the floor rusted in the corners. I would only be concerned if it was a "beach Jeep", meaning it's been driven on the beach. Salt water and Jeeps do not mix.
However, it looks like the last PO attempted to repair the neglect of the first by bedlining the floors, replacing the soft top, and doing some upgrades. If that is just surface rust in the corners, it'll be easy to fix with some sanding and some paint. Overall, with that low of mileage for the year, the body should be in good overall condition with minimal surface rust unless it was a "beach jeep".
One thing you can do is literally poke the floors and the frame to check for soft spots with a screw driver. Frame rust is actually more of a problem with TJ's as they tend to rust from the inside/out from winter driving in particular.
06philaTJ is offline
post #18 of 39 Old 06-30-2013, 04:41 PM
BamaJeepman21
Look at that frame in the last picture. It looks brand new.
OP ask the dealership to send you undercarriage pics. $7,000 is still high but it only has 57,000 miles. That's amazing for a '99, hence the price. If you could get it for $7,000 out the door with tax, title, doc, license...etc then it would be a great deal.
edit: I mean look at these prices for later SE's...
http://www.autotrader.com/cars-for-s...gIndex=1&Log=0
http://www.autotrader.com/cars-for-s...gIndex=3&Log=0
-Jack
BamaJeepman21 is offline
post #19 of 39 Old 06-30-2013, 04:52 PM
Kodiak17
Do some research before actually buying anything for hp. Most find a few hundred dollars put into the 2.5L does very little compared to regearing your axles.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #20 of 39 Old 06-30-2013, 05:06 PM
Ljcrawler05
In your picture of the front of the vehicle why is it leaning so far over? Or is it just the picture? Might wanna check for frame damage and suspension components
Ljcrawler05 is offline
post #21 of 39 Old 06-30-2013, 05:22 PM
KansasCityTJ
Sorry just went to check on the jeep, but it is a 2.5. But are those engine blocks strong or is it worth to put some more power in?
I will not use it for heavy offroad
post #22 of 39 Old 06-30-2013, 05:34 PM
BamaJeepman21
Nothing short of cams, boring it..etc will give it any power.
Besides that, the 2.5 is an execellent engine in terms of reliability.
-Jack
post #23 of 39 Old 06-30-2013, 05:57 PM
MrSundays
Big difference. In terms of reliability, yes the 2.5 is reliable, but so is the 4.0. If you ask anyone with a 4 banger they will tell you to save the headache and get a 4.0. My buddy just bought an 05 with the 4 banger and he already wishes he got the 4.0. I'm not saying you made a mistake, just understand you're not going to eat the 4.0 power short of turbocharging the motor. All I'm trying to get at is there's a reason the 4 bangers are cheaper.
Sent from my pocket brick
SOLD- '13 JKR with lots of goodies
Current- '98 TJ Sahara: build coming in October
MrSundays is offline
post #24 of 39 Old 06-30-2013, 06:02 PM
KansasCityTJ
So what do you recommend doing with the engine?
post #25 of 39 Old 06-30-2013, 06:07 PM
MrSundays
Drop a 4.0 in it or a v8 stroker. I work with a guy who has a 350 in his and loves it
post #26 of 39 Old 06-30-2013, 06:44 PM
KansasCityTJ
Any idea what the cost is? I just want some more power in it to get trough mud and snow
post #27 of 39 Old 06-30-2013, 06:53 PM
BamaJeepman21
Or you could just gear it right...
-Jack
post #28 of 39 Old 06-30-2013, 06:56 PM
MrSundays
Try it stock first and see how you like it. You might end up loving it!
post #29 of 39 Old 06-30-2013, 07:07 PM
KansasCityTJ
Allright, thanks for the info. As my first car i am proud of it and in a couple months i am just goig to try to put some hp in it
post #30 of 39 Old 06-30-2013, 07:16 PM
rondak46
You guys stomped all over the OP's thread
rondak46 is offline
first jeep , tj
