My Final Word On Cold Air Intakes - Page 5 - JeepForum.com
post #61 of 70 Old 03-01-2010, 11:14 AM
biffgnar
biffgnar's Avatar
Originally Posted by Tmblack3 View Post
thats what i was also thinking. with the size of the intake tubing and all, didnt yall say that the smootheness of a cold air intake wouldnt help performance? if not then i might just leave the filter and reroute the filter intake to the cowl. also, how have yall mounted your airboxes? i do rough offroading all the time so it would have to be mounted durably.
also, what about a cone or cylinder filter? that would eliminate the whole concept of an airbox and mounting. i was thinking a similar setup to kiddo's first pic in this thread, just in the cowl.
Feeding the the intake into the cowl and then attaching to the connecting tube to the throttle body makes the box pretty snug. There's also not a lot of room under there for it to move generally I did put one (or two) zip ties on it, but its not going anywhere.
biffgnar is offline
post #62 of 70 Old 03-01-2010, 11:48 AM
Tmblack3
i meant if the airbox was relocated underneath the cowl, which is what a couple people have done if i understand correctly.
04 TJ Sport- Kicker System, Smittybilt XRC-8 Winch, Cherry Bomb 18" Glasspack, 3" Zone Hydro Suspension Lift, 33x12.50 BFG KM2, 15x8 Procomp 7069, Aussie Locker front Dana 30, JKS 1.25" Body Lift, 4 100w Hella 500s
Tmblack3 is offline
post #63 of 70 Old 03-01-2010, 12:34 PM
biffgnar
biffgnar's Avatar
Its pretty snug in the cowl, I would imagine by the time you get your filter and any connecting tubing in there and tighten the cowl cover down that nothing will be moving.
biffgnar is offline
post #64 of 70 Old 03-01-2010, 01:01 PM
Tmblack3
ok, well i havent taken a look for myself so i wouldnt know. but are there any negatives to using a cylinder or cone filter under the cowl compared to the setup by kiddo?
Tmblack3 is offline
post #65 of 70 Old 03-01-2010, 01:17 PM
biffgnar
biffgnar's Avatar
I don't have personal experience with those so not my place to just repeat what I have read. Do a search for any of the brand names of popular under hood after market filters and you will find plenty of opinions . . . . most of them negative.
biffgnar is offline
post #66 of 70 Old 03-01-2010, 04:02 PM
Tmblack3
well im thinking a cylinder or cone filter would be much simpler, and just provide cover from rain and mud with a scoop and some screen/prefilter on the cowl vent.
Tmblack3 is offline
post #67 of 70 Old 03-01-2010, 04:39 PM
Tmblack3
and the bad opinions about after market air filters are either lack in performance increase or lack in filtration, im just talking about the idea and concept of a simpler filter that does NOT require an airbox.
Tmblack3 is offline
post #68 of 70 Old 03-07-2011, 01:34 PM
BC Jeep
Wow! This post has given me SOOOOO many great cold air MOD Ideas! WELL DONE! I even have a Ford F-150 filter assy off my old 97 F150 that I can use!
I also like the Idea of moving the IAT sensor. I plan on making a MAP sensor scaler and using my wide band O2 sensor to adjust my Air Fuel Ratio. Cant wait to see the results. You can BET that there will be picture attached!!!
BC
BC Jeep is offline
post #69 of 70 Old 03-07-2011, 01:46 PM
wahooz04jeep
Originally Posted by Robz2000 View Post
I recently modified my air intake using the stock air box. Ive seen a lot of these aftermarket filter on a stick designs for over 200 bucks but all i did was remove the small stock snorkel and made a small ram air with a smoother bend in it about 2 1/2 in diameter with the opening sitting right next the core support next to the gap when the hood is closed. No more sucking in hot air and that gap on jeeps is so wide it sucks or rams in plenty of cool outside air. Then i kept the stock air box but put in a drop in K&N filter. Next i replaced that cheesy stock intake tube with all the extra bends , that accordion section and the small diameter of 2 inches with ABS tubing,connectors from Home Depot, gained an extra inch in diameter and more direct to throttle body design. oh plus i put in a push in breather filter on top of valve cover. Wow, what a difference it made in performance plus it looks good . Im telling u, i used to fall back going up hills , now it pulls away. i can send pics , email if anyone interested.
You're PM box is full Robz. Can you PM me:
build up w/ parts, tools, and some pics?
2007 Jeep Patriot Sport
OlllllllO
I wave
wahooz04jeep is offline
post #70 of 70 Old 03-07-2011, 03:15 PM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Doesn't look like he's been on since April 2009.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
Cold Air Intakes... DaveV TJ Wrangler Technical Forum 19 01-30-2009 07:47 AM
Cold Air Intakes Redboots TJ Wrangler Technical Forum 5 07-06-2008 08:07 PM
final word on air intakes? derfin TJ Wrangler Technical Forum 5 09-26-2007 08:07 AM
Timing and the Nutter bypass the final word! toxin YJ Wrangler Technical Forum 10 01-24-2007 04:42 PM
Cold Air Intakes Fishpilot TJ Wrangler Technical Forum 32 03-09-2005 09:44 PM
