My Final Word On Cold Air Intakes - Page 4 - JeepForum.com
post #46 of 70 Old 02-26-2010, 07:43 PM
Ross
Originally Posted by biffgnar View Post
And your stock intake or an open under hood filter would be better? If water is over the top of the hood those are going to be underwater. If you've got enough water coming over the top of your hood such that its all the way to base of the windshield the only type of intake that saves you is a snorkel. Actually, even with this mod I wouldn't want to be deep enough that water was coming over top of hood. Would worry about cowl filling from the bottom up through the drain. That being said IMO cowl is better place for intake than stock for a couple reasons - higher, cool air, avoid dipping front end into holes, fan doesn't throw water into intake, etc.
When water enters the stock box it enters below the filter. There are holes in the stock box for the water to drain. Water is heavy and you motor isn't going to suck it in unless you saturate it. I have had water come into my box more than once. The bottom of the box had mud, twigs and leaves in it but the filter is still dry. It is a good design. There have many times where I have gone through water and it has run acroos my hood, not water that deep but it has washed across my hood esp. when moving with any speed. With this design you have gravity working against you. The water will settle on the filter and quickly saturate it, no avoiding that. With much more than a puddle or a heavy mist that desgin but the motor at risk.
I will admit it will draw cooler air, but a snorkle would be a better option.
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #47 of 70 Old 02-27-2010, 10:35 AM
biffgnar
biffgnar's Avatar
If you're talking about water just washing over the hood but not truly that deep the OP's setup could result in a soggy filter. My setup breathes through the cowl, but the filter is in a windstar box under the hood. My intake is not directly under the vent, obviously comes into the cowl at a right angle to the vent and is a couple inches off the bottom of the cowl. Water going down vent should just go straight down and out cowl drain (which is pretty big on my 06) as long as I keep it open and not get pulled into the intake.
biffgnar is offline
post #48 of 70 Old 02-28-2010, 07:41 AM
Tmblack3
sorry if this is a stupid question, but how do you get to the area underneath the cowl vent? i understand all of this, just not completely understanding how the whole filter/airbox gets underneath the vent.
04 TJ Sport- Kicker System, Smittybilt XRC-8 Winch, Cherry Bomb 18" Glasspack, 3" Zone Hydro Suspension Lift, 33x12.50 BFG KM2, 15x8 Procomp 7069, Aussie Locker front Dana 30, JKS 1.25" Body Lift, 4 100w Hella 500s
Tmblack3 is offline
post #49 of 70 Old 02-28-2010, 07:59 AM
robncar
robncar's Avatar
Remove wipers, remove screws, remove cowl...
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #50 of 70 Old 02-28-2010, 08:07 AM
03JeepTJ
I'm really thinking about doing this.. I mean, what do you honestly have to lose? But I like the way the filter sits in the Before Picture.. But could it stay there? or did you move it because it was getting water or something?
2003 Jeep Wrangler TJ Stock for now with 31 Dunlop Mud Rovers
03JeepTJ is offline
post #51 of 70 Old 02-28-2010, 08:08 AM
Tmblack3
ok, makes sense, thanks! just didnt know how yall were going about it but i thought it was something like that. forgot how simple removing jeep parts was lol.
Tmblack3 is offline
post #52 of 70 Old 02-28-2010, 08:11 AM
biffgnar
biffgnar's Avatar
If you do this mod and then put on a cowl scoop be careful not to cover up the screw by the vent with your cowl scoop. Makes it hard to remove the cowl next time if you do cover it up. Seems simple right? Of course nobody would ever be that dumb. Well . . . . .
biffgnar is offline
post #53 of 70 Old 02-28-2010, 08:19 AM
Tmblack3
lol, hate stupid mistakes. so what airbox should i use for this? i want to be as direct as possible to have best performance.
Tmblack3 is offline
post #54 of 70 Old 02-28-2010, 10:12 AM
biffgnar
biffgnar's Avatar
I used a Windstar box. I believe Buick boxes are popular also.
biffgnar is offline
post #55 of 70 Old 02-28-2010, 04:01 PM
Tmblack3
ive looked at them, cant seem to find what yall are talking about, can someone link me one?
Tmblack3 is offline
post #56 of 70 Old 02-28-2010, 05:12 PM
biffgnar
biffgnar's Avatar
mudb8's post #41 in this thread has a picture of the windstar box. In that picture he hadn't run it to the cowl yet, although says he was going to. My box is from 98 3.8L Windstar. Bought it on Ebay.
biffgnar is offline
post #57 of 70 Old 02-28-2010, 09:21 PM
Tmblack3
so the reason that yall are preferring these airboxes is because the intake hose location will work with the cowl induction setup right?
Tmblack3 is offline
post #58 of 70 Old 02-28-2010, 09:41 PM
iceman8
Cowl removal can be a bit tricky, so if you care...tape up the edge of the hood and perimeter outside the cowl because you could scratch up those areas removing/reinstalling it. It has to be finessed into place. Also, think about lubing the working parts of the wiper mechanism under there. Mine was bone dry at every moving point/part.
iceman8 is offline
post #59 of 70 Old 03-01-2010, 08:34 AM
biffgnar
biffgnar's Avatar
I think leaving box under the hood is a lot simpler. Didn't have to mess around with fitting anything in the cowl. Just had to drill through the firewall with a holesaw for the intake. Don't have to pull the cowl when I want to change filters.
biffgnar is offline
post #60 of 70 Old 03-01-2010, 08:44 AM
Tmblack3
thats what i was also thinking. with the size of the intake tubing and all, didnt yall say that the smootheness of a cold air intake wouldnt help performance? if not then i might just leave the filter and reroute the filter intake to the cowl. also, how have yall mounted your airboxes? i do rough offroading all the time so it would have to be mounted durably.
also, what about a cone or cylinder filter? that would eliminate the whole concept of an airbox and mounting. i was thinking a similar setup to kiddo's first pic in this thread, just in the cowl.
Tmblack3 is offline
Cold Air Intakes... DaveV TJ Wrangler Technical Forum 19 01-30-2009 07:47 AM
Cold Air Intakes Redboots TJ Wrangler Technical Forum 5 07-06-2008 08:07 PM
final word on air intakes? derfin TJ Wrangler Technical Forum 5 09-26-2007 08:07 AM
Timing and the Nutter bypass the final word! toxin YJ Wrangler Technical Forum 10 01-24-2007 04:42 PM
Cold Air Intakes Fishpilot TJ Wrangler Technical Forum 32 03-09-2005 09:44 PM
