My Final Word On Cold Air Intakes - Page 2 - JeepForum.com
post #16 of 70 Old 07-05-2008, 06:06 PM Thread Starter
Kiddo86
Originally Posted by UTWeezul View Post
Looks good. Move the IAT sensor onto the intake tube. I had to extend the wiring and buy a new sensor so that the old one keeps the hole plugged up on the air intake. When Jeep put the sensor in the manifold, it heat soaks the IAT and causes the computer to think the air coming in is really hot. I drilled a 3/4" hole in the intake tube and put in a rubber gromet and put the new IAT into that hole. This is why Jeep moved the IAT on 05 and 06 Jeeps.
Is that the sensor mounted just below the where the header meets the head pipe?
Kiddo86 is offline
post #17 of 70 Old 07-05-2008, 06:50 PM
jake1977
That is very interesting,any feedback on this? Anyone notice a difference?
jake1977 is offline
post #18 of 70 Old 07-05-2008, 07:24 PM
UTWeezul
This is it. Mine was located behind the throttle body though.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #19 of 70 Old 07-06-2008, 10:50 PM
Rikarus
2015 JK Wrangler
Awesome mode, that lookspretty nice, do you have any performance numbers yet?
The joint looks like it is a tad smaller than your intake tube, does this added ventri cause and issues?
2005 Rubicon Black
1988 Wrangler Yellow
Rikarus is offline
post #20 of 70 Old 07-07-2008, 11:28 AM Thread Starter
Kiddo86
The joint is very slightly smaller... but I seriously doubt that it's a bottleneck in the intake.
On top of getting cold air into the engine... I really appreciated being able to wash my engine without covering the filter after wheeling this weekend!
Kiddo86 is offline
post #21 of 70 Old 07-16-2008, 02:38 PM
Heavylift
On the topic of the IAT relocation:
I messed around with a couple intake setups. Ended up with my current one, threw relocating the IAT sensor and a computer reader,I mapped out air/fuel mixtures and intake air temperature. There's huge differences between the free air temperatures. Stock intake my temperatures were 99-101 degrees at running temperature. I relocated the IAT sensor just short of the stock intake box and it was still around 98-100 alibi: i did not have that little horn on the box. After making a super low budget ie. 50 dollar, intake setup and mounting the IAT sensor prior to the cleaner the temps dropped to 94-95. Then I made a heat shield and attempted to close it off totally from the engine compartment and made sheet metal modifications so air flows around the hood into the chamber and around the passenger side headlight into the chamber, the temps dropped significantly to more or less outside air temperature, I've seen low 50's in the winter since, but the day I did it for comparison sake was 77 degrees. When the ECM maps out the fuel mixture it takes the IAT and manifold absolute pressure together to configure the air-fuel mixture. So yes the ECM does know. This is no theory, I've worked on the Turbine engines on the aircraft I now fly, their are giant curves in performance for intake air temperature. Obviously not as substantial on our 4.0L. And it doesn't just ramp your mixture up to rich either, it maps it out, at idle and up threw 1/4 throttle there's little difference, where it jumps is prior to and at WOT. I try not to end up there, but there is a change in fuel mapping. I try to be conservative in the modifications I do and driving, I don't want a gas guzzling hog, I could care less about being fast, my goal is overall engine efficiency with a delectable exhaust tone.
Notice the postition of the IAT sensor right prior to the heat shield:
This video was before the porting of 99+manifold and head, and before the APN headers.
[YT]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/u7rDRwBGyGs&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/u7rDRwBGyGs&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>[/YT]
Background on my engine setup: 98 4.0L with homemade intake, Flex-a-lite electric fan, 62mm throttle body, 99+ ported intake manifold, ported head, indexed and side gapped auto lite spark plugs, APN headers 2.25" at the collar to 2.5" pipe around and out to a Flowmaster super 40 series and out the back. Choking it down to 2.25, then back up to 2.5" helps the low end torque.
Heavylift is offline
post #22 of 70 Old 07-16-2008, 03:36 PM
valacech
valacech's Avatar
That is outstanding. Nice Jeep if I do say so myself. Interesting design you came up with there... very unique. I am fearful that you will encounter some serious issues with that design, however. First of which would be the water/snow situation. I am not sure where you are from, but if it snows you could face a potentially damaging situation. I am interested in seeing how you will tackle this potential problem given your ingenuity with this design. Please keep us posted. Also, what is that vent exactly for anyway? I do not even know that. I am hopeful that you are not causing potential problems for yourself by perhaps blocking off something that is very much necessary for your Jeep to perform over time. I am greatly intrigued by this and am curious to see the future of this project. Outstanding!
You are not a unique snowflake.
valacech is offline
post #23 of 70 Old 07-16-2008, 03:48 PM
87warrior
87warrior's Avatar
This is where your rig brings fresh air for the AC/Heat unit. The fan is on the passanger side under the cowl. You will have no worries unless your Jeep backfires through the TB (something would have to go really wrong). One of those "truck master" cowl scoops turned backwards would do a find job at keeping the filter dry. It would also be possible to stick some sheet metal in there to simply redirect the water down and out the cowl drain.
I have a cowl intake too. I do believe it helps.
03
(Rubicon build)
92
(92/99 Comanche Project)
86
(Heavy Four)
87warrior is offline
post #24 of 70 Old 07-17-2008, 02:31 PM
patricknolan
Bad design. I guess its not so bad for you since you have a 'rain' vehicle. What if it decides to rain while your at the supermarket??? your screwed.
patricknolan is offline
post #25 of 70 Old 07-18-2008, 10:04 PM
badoosh27
badoosh27's Avatar
i had a setup just like that one, and i did get stuck in the rain and it flooded my engine, didnt hydro lock tho. i have since changed the design to one that uses a fram filter inside a gallon paint can that sits just above the valve cover. my milage jumped from about 15 to 17.5. i also have a scoop (air vent deflector from lowes/home depot ($4)) facing the windshield which helps too.
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
post #26 of 70 Old 09-04-2008, 04:41 AM
brian674
Why not just make a Snorkle? It would solve both problems, I would think.
'There is nothing more deceptive than an obvious fact.' Sherlock Holmes
brian674 is offline
post #27 of 70 Old 09-04-2008, 09:47 PM
TOLjeep
Ehh Im gonna stick to my K&N kit. To me that was the best thing i have yet done to my Jeep for performance. Brought the 4.0 to life.
2003 Jeep Wrangler Sport Dana 30 Front, Dana 35 Rear, 5 Speed
2.5'' Rough Country Suspension
33x12.50 Mud Grapplers on 17" Black Rock Vipers
Mopar Rubicon Rockers,Warn Front Bumper, Bestop Rear Bumper, Banks Exhaust, K&N FIPK
Next: 1.25 Inch Body lift, SAVVY Corner Armor and Steering, PSC Rocker Knockers
Down the Road: Ford 8.8, 3 Inch Springs, 35" Mud Grapplers on Black 20's
TOLjeep is offline
post #28 of 70 Old 09-04-2008, 10:20 PM
socatevoli
I really dont think you would have to worry about rain or snow. I had a cai on my jetta that was 2 inches from the road right in front of my drivers side tire, and it went through heavy down pours and snowy winters with no probs. You really have to be submerged in somthing to hydro your engine. Just put a cover over it like you were saying and you'll be fine
socatevoli is offline
post #29 of 70 Old 09-07-2008, 08:47 AM
Fourbycor
Fourbycor's Avatar
How come nobody just louvers the hood to disapate some heat? Gen-right and a couple of others make some nice louvers...simple to install and keeps the changing of the air filter (or checking it) simple....my 2 cents
'02 YellowTJ Sport, 5-speed, Custom 4-link/3-link, King Coilover's, GenRight stuff, 37" Nitto's on Raceline's, Tom Woods Shafts, ARB's, RCV Shafts, Reid Knuckles, 5.13's, PSC Hydro assist, Rock Hard Cage, Warn M8000, Teralow 4:1.
Proud member of the 2011 & 2012 Ultimate Adventure
Fourbycor is offline
post #30 of 70 Old 10-16-2008, 08:28 PM
Robz2000
home made air intake
I recently modified my air intake using the stock air box. Ive seen a lot of these aftermarket filter on a stick designs for over 200 bucks but all i did was remove the small stock snorkel and made a small ram air with a smoother bend in it about 2 1/2 in diameter with the opening sitting right next the core support next to the gap when the hood is closed. No more sucking in hot air and that gap on jeeps is so wide it sucks or rams in plenty of cool outside air. Then i kept the stock air box but put in a drop in K&N filter. Next i replaced that cheesy stock intake tube with all the extra bends , that accordion section and the small diameter of 2 inches with ABS tubing,connectors from Home Depot, gained an extra inch in diameter and more direct to throttle body design. oh plus i put in a push in breather filter on top of valve cover. Wow, what a difference it made in performance plus it looks good . Im telling u, i used to fall back going up hills , now it pulls away. i can send pics , email if anyone interested.
Robz2000 is offline
Cold Air Intakes... DaveV TJ Wrangler Technical Forum 19 01-30-2009 07:47 AM
Cold Air Intakes Redboots TJ Wrangler Technical Forum 5 07-06-2008 08:07 PM
final word on air intakes? derfin TJ Wrangler Technical Forum 5 09-26-2007 08:07 AM
Timing and the Nutter bypass the final word! toxin YJ Wrangler Technical Forum 10 01-24-2007 04:42 PM
Cold Air Intakes Fishpilot TJ Wrangler Technical Forum 32 03-09-2005 09:44 PM
