My engine warning light is on? Should I be worried? - JeepForum.com
post #1 of 7 Old 08-29-2010, 03:22 PM Thread Starter
RedHotChiliDog
Today is the first day that it caught my eye that it stays on the entire time I'm driving. It may have been on for awhile but idk I'm just confused and nervous! I read the manual and it basically said that ****s about to break if it starts flashing which it isn't! But why is it flashing and should I be worried? btw, I gave my jeep a new oil change with fully synthetic oil, which isn't cheap and I greased it.
RedHotChiliDog is offline
post #2 of 7 Old 08-29-2010, 03:23 PM
biffgnar
biffgnar's Avatar
biffgnar is offline
post #3 of 7 Old 08-29-2010, 03:28 PM
ecm
Scan it and see what the code is. It could be something as simple as a loose or defective gas cap. Autozone will scan the computer for free.
ecm is offline
post #4 of 7 Old 08-29-2010, 04:11 PM Thread Starter
RedHotChiliDog
thanks guys! I'll report back after I go do it
post #5 of 7 Old 08-29-2010, 04:48 PM Thread Starter
RedHotChiliDog
I just tried this but the engine light just says lit so I guess I'll call bell tire tomorrow and see of they can do it for free
post #6 of 7 Old 08-29-2010, 06:54 PM
ecm
Head to an Autozone before they close and they'll scan you for free. Unless you live out in the boonies, there's got to be an Autozone nearby.
ecm is offline
post #7 of 7 Old 08-29-2010, 07:06 PM
Jeepster2k3
just turn your key 3 times and it will tell you what codes it currently has
go from the on (not start) to the off (don't hold the button just put in the off position) 3 times and watch the display window it will tell you
Jeepster2k3 is offline
check , engine , light , CEL
Engine warning light, code P1196 (oxygen sensor) planetlarson TJ Wrangler Technical Forum 1 09-05-2009 11:51 AM
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 08:29 AM
Random engine light warning? jeepsteve TJ Wrangler Technical Forum 7 02-22-2008 07:23 AM
Engine Warning Light-Help cromwell TJ Wrangler Technical Forum 6 03-21-2005 11:21 AM
Warning light magna YJ Wrangler Technical Forum 1 07-03-2001 12:23 PM
