my engine cranks, but doesnt start - JeepForum.com
post #1 of 14 Old 11-06-2006, 08:07 PM Thread Starter
TXjeepTJ
TXjeepTJ's Avatar
my engine has been doing fine for the past year, no problems at all
this morning i started it up, shifted into reverse(ax15 manual 5sp) and let off the clutch a little and it died
once it died it wouldnt start back up
all fuses are intact and fine... what could be the problem?
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #2 of 14 Old 11-06-2006, 08:13 PM
off-road arkie
unhook your battery for 30 seconds and then hook it back. let the computer reset itself.
1987 6 banger " if it's runnin be happy" & 03 and it is running fine
off-road arkie is offline
post #3 of 14 Old 11-06-2006, 08:38 PM
McLovin
Well you are either not getting air, spark or gas. If your getting all 3 of those it will at least run. Check it and see, could be a fuel pump went out.
McLovin is offline
post #4 of 14 Old 11-06-2006, 08:38 PM
daveg13
daveg13's Avatar
Could possibly be your fuel pump. Check to see if you have pressure at the fuel rail. They'll be a schrader valve on the rail.
daveg13 is offline
post #5 of 14 Old 11-06-2006, 09:10 PM Thread Starter
TXjeepTJ
TXjeepTJ's Avatar
well i can hear the fuel pump activating when i turn the car on-- could it still be blown out?
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #6 of 14 Old 11-06-2006, 11:11 PM
blkfreedom03
blkfreedom03's Avatar
crank position sensor maybe?
Present: '03 Wrangler Freedom Ed. 4.0/NV3550 - Dynomax cat-back, 30" BFG ATs, black steelies..
Past: '94 ZJ Laredo 5.2/46RH
Black Jeep Society
blkfreedom03 is offline
post #7 of 14 Old 11-06-2006, 11:43 PM
$lick
my fuel pump went..it would turn on when i had my ear to the tank and had someone click the key over. It was blown, i replaced the TPS and CPS.. thinking that would be the cheaper fix..NOPE.
and on my 97 i didnt have the shrader valve they speak of
1997 Wrangler 2.5L 5spd
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
Teraflex adjustable front trac bar
JKS Disco's
Axle specs:
Dana 30- Superior 4.88's
Detriot tru-trac locker
Dana 35- Superior 4.88's
Riding on:
33x12.50 BFG A/T
Black Cragar soft 8's
$lick is offline
post #8 of 14 Old 11-07-2006, 03:03 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
it'll never start if you keep calling it a car...
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
USN Hull number 54
Poor Boy is offline
post #9 of 14 Old 11-07-2006, 05:32 AM
PDX_XJ
PDX_XJ's Avatar
Pop off your air tube and spray some wd40 or other flammable substance in there while someone cranks it for you. If it lights, you have a fuel problem. If not, you have a spark problem.
  • Armor's Axiom: Virtue is the failure to achieve vice.
  • The sooner you fall behind, the more time you have to catch up.
PDX_XJ is offline
post #10 of 14 Old 11-07-2006, 09:11 AM Thread Starter
TXjeepTJ
TXjeepTJ's Avatar
i used some starting fluid to do it, nothing happend at all
must be spark plugs?
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #11 of 14 Old 11-07-2006, 09:43 AM
jeeptj19992001
if you are not getting spark, start here, also check your distributor cap and coil
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #12 of 14 Old 11-07-2006, 11:29 PM Thread Starter
TXjeepTJ
TXjeepTJ's Avatar
im not getting spark, so my guess is to go ahead and buy the crank positioning sensor? i hear its pretty easy to install and doesnt cost much
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #13 of 14 Old 11-08-2006, 05:58 AM
PDX_XJ
PDX_XJ's Avatar
Check your distributor cap and coil first. I'd hate to be out the money (no matter how small) for the position sensor when it was something like a loose coil wire.
PDX_XJ is offline
post #14 of 14 Old 11-08-2006, 06:01 PM Thread Starter
TXjeepTJ
TXjeepTJ's Avatar
i check the coil and distributor cap, i measured the coils ohms with my multimeter and it showed 11 ohms k, which is right
and the cap looks fine
... i bought a crank positioning sensor and held it in place(because i want to be able to return it) and had someone crank it, still nothing- didnt start
cam shaft positioning sensor maybe?
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
Cranks and Cranks, cranks some more and she wont start. crzylgzz YJ Wrangler Technical Forum 37 12-09-2011 04:44 PM
2.5 cranks but wont start...Cold start SnowdogMarc YJ Wrangler Technical Forum 4 08-04-2009 08:16 PM
4.0L cranks but no start, no roll start flame0086 YJ Wrangler Technical Forum 11 06-15-2009 06:00 PM
My Jeep Cranks And Cranks But No Start!!! b1ack2tar YJ Wrangler Technical Forum 5 01-14-2009 09:23 AM
Electrical short, engine cranks but won't start... JeepDad YJ Wrangler Technical Forum 1 10-23-2001 01:42 PM
