Quantcast my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee
Old 03-29-2009, 11:15 PM   #1
bulickmcj
i have a 2000 tj with a dana 35 axle with 373 gears and it snapped for the second time now i have a dana 35 axle out of a 1990 Cherokee with 373 gears can i just swap the spider gear and everything else ??
bulickmcj is offline   Reply With Quote
Old 03-29-2009, 11:20 PM   #2
Dmcastino
Not sure if can swap it or not, but if you have snapped it twice now, have you thought about strengthening it rather than just returning it to stock so it can break again?
Dmcastino is offline   Reply With Quote
Old 03-30-2009, 12:08 AM   #3
Jeepster83
X2. youve obviously found a recurring problem with your Jeep. so rather than repairing it over and over spending more money than youd like, just upgrade it. i kept bending tie rods and drag links and replaced the stock stuff 3 times before i sprung for the upgraded Currie kit.
wise words spoken on this site occasionally; spend a little more and complain about it once, or save now and complain over and over.
look into a c-clip eliminator kit for your axle if you dont want to swap axles or get a S35. you can do it yourself very easily with common hand tools and a drill (Superior even supplies the drill bit). ive seen it as low as $550 and as high as $700 so shop around if you get the kit.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Currently seeking employment in the automotive field or fabrication. PM me for resume and list of qualifications.
Jeepster83 is offline   Reply With Quote
Old 03-30-2009, 05:05 AM   #4
jeep2008
your problem are the shafts braking or the spider gears?anyway i wouldn't trust a 20 years old axle under my jeep.buy a truetrak to replace your spider gears and a superior c-clip eliminator and you are golden!
my build thread
04TJ (SOLD)
01TJ (BUILDING)
jeep2008 is offline   Reply With Quote
Old 03-30-2009, 07:01 AM   #5
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The spider gears are different.
There are 2 different side gear diameters for the D35 - 1.56" and 1.62".
The earlier models (pre '92 or '93) all have the larger 1.62" side gears.
The difference is between ABS and non ABS. Starting around '92-'93, all D35 axles used the ABS style carrier with the smaller side gears, regardless if they had ABS or not.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 03-31-2009, 07:15 PM   #6
bulickmcj
i got it all apart turns out the guy wielded the spiders in the Cherokee axle anyways. i am trying to fix it for now cause i am laid off work and cash is tight right now. i broke a tooth off of two spyder gears, how much am i looking at a tru trac i already have yukon axle shafts with 27 spline
Old 03-31-2009, 07:28 PM   #7
Jeepster83
4x4groupbuy.com has a trutrac for $369
Old 04-02-2009, 12:42 PM   #8
bulickmcj
reply ok i think thats what im gona do i got another axle for a hundred bucks for now i will just build the other one up when i get the money. thank you guys for your help and info
Glock Forum
