MY A/C is out, did search - JeepForum.com
post #1 of 7 Old 07-30-2010, 07:41 AM Thread Starter
Ross
I am fairly confident it is the resistor back. I have found what I think to be the resistor pack. Does it have three wires coming out of it and located passenger side under the dash close to the center console?
I have an 01 I-6 5spd.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #2 of 7 Old 07-30-2010, 07:51 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
TheBoogieman is offline
post #3 of 7 Old 07-30-2010, 06:19 PM Thread Starter
Ross
Thanks
Ross is offline
post #4 of 7 Old 07-30-2010, 06:47 PM
Hondo
Did the picture thread help you? I had this problem last weekend and it is located behind the glove box in the lower right hand corner below the neon green connector. There are 2 bolts to remove, one from inside the glove box hole, and one from underneath the dash. I removed the floor light as well to gain some space. Removing the green connector from whatever holds it in place will allow you to drop the resistor pack down below the dash to be able to remove it from its connector easier, which is a whole 'nother pain in itself! Good luck.
Hondo is offline
post #5 of 7 Old 08-02-2010, 06:50 AM Thread Starter
Ross
Mine is an 01 and is different. I found another write up here. Both write ups are very good. Switched it, still had the problem. Did a little more research and I think it is the switch, which nobody local has in stock.
Ross is offline
post #6 of 7 Old 08-02-2010, 07:27 AM
Joeggernaut
im going through the same problem. The problem happens because the blower motor fan wears out and draws more current and overloads the wires/resistor/switch and burns it.
Replacing the wires/switch/resistor only hides the problem short term and it will come back.
Replacing the motor/switch/resistor should last 5 years plus like your old setup but eventually will happen again.
Permenant fix and the one I am undergoing right now is new motor/switch/resistor and adding 4 relays in between the switch and the resistor to cut down on power if the new motor does go bad.
you can get the motor from ebay for bout 40 bucks, switch and resistor from quadretec pretty cheap and the relays online.
this thread has the fix basically
AC blower motor switch burn out - Jp Magazine Forums at Jp Magazine
you can do the fix without a new motor also.
Joeggernaut is offline
post #7 of 7 Old 08-02-2010, 08:34 AM Thread Starter
Ross
Thanks
Ross is offline
ac , a/c , resistor pack , tj , wrangler
Can some one search for me.. Barrio YJ Wrangler Technical Forum 14 01-28-2008 07:41 PM
search .. help me! minileprechaun TJ Wrangler Technical Forum 9 04-12-2006 04:43 PM
search jptaylor2 TJ Wrangler Technical Forum 3 04-03-2006 05:16 PM
Nutter Bypass Search. How do I search? samahi72 YJ Wrangler Technical Forum 1 03-20-2006 03:40 PM
Search is OVER! 97 TJ'd up TJ Wrangler Technical Forum 11 11-20-2005 08:25 AM
