My build thread for those of us with low budgets!
#16 | |
If your wheeling in the woods, those kind of light bars love to grab tree limbs as you ride and poke them through your soft tops. I have a Garmin Wilderness rack, I'll be putting some steel mesh on mine to keep that same thing from happening.
My lift and tire cost me 790. Got the lift, tires, and wheels all here for 790. Deals are out there, keep your eyes open. I love the console, by the way.
Chrome can get you home, you can signal the search aircraft with it! |
#17 |
I have no clue. They where used for KC daylighters. I am not sure why they would not work. I also have no clue about shipping, but if you want them I will send them out and you just send me the money once you get them and make sure they work. send me a pm if you want them
If I can get there I can wheel it! CentralMass4wd.com 1993 Ranger 2wd - dd 1999 wranger 2.5 - it gets used for something 1978 international scout - being built 1998 Cherokee sport 4.0 auto 1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/f8/restoring-57-cj5-stock-build-thread-553649/#post5168554 Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900 my build http://www.jeepforum.com/forum/f9/my-build-thread-those-us-low-budgets-550786/ |
#18 |
PM'ed ya on the brackets!
Just Keele-n-time......... [QUOTE=robncar;5113545]It took me a while to realize urine was yellow and shouldn't have blood in it[/QUOTE] |
#19 | |
I love that color, you dont see many of them around and thats why im happy to be rockin' the same color.....nice jeep man
1999 TJ Wrangler, 4 banger 5-spd Soft-top, full doors 31" BFG AT, 3" Lift 1954 CJ3B Willys Hurricane 4, 3-spd with Warn Overdrive, Snow-plow NGJC# 15 Low Output 4 cylinder Jeep Club Member #166 Build Thread Are You An Offroad Junkie Quote:
#20 |
If you dont sell those brackets and arnt askin too much I'll take um
![]() Same boat as your poor highschool kid with WAY to thin of a wallet, Good luck with your build up! |
#21 |
I sent some one a PM on them earlier. I do not think I am charging too much. I hope not at least, I would hate to rip some one off. I was asking $25 shipped.
Anyways I got my lights on and lit up. I worked on them at night in the rain but they are so bright! The names under the switches light up green also! I am working on getting more lights! I need to get one bulb for a KC daylighter but not sure where. I suppose I will look on line.
If I can get there I can wheel it! CentralMass4wd.com 1993 Ranger 2wd - dd 1999 wranger 2.5 - it gets used for something 1978 international scout - being built 1998 Cherokee sport 4.0 auto 1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/showthread.php?p=5168554#post5168554 Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900 my build http://www.jeepforum.com/forum/showthread.php?t=550786 |
#22 |
By the way have you seen this write up for $6.38 (grade 8 hardware all around) I was able to get a ton more flex
http://www.4x4xplor.com/homediscos.html Another thing you can do is buy 24" of steel tubing (square) 1inch, cut down to 2 " sections for the front and 2 3" sections for the back and get new bolts you can make 1" seat risers which are way more comfortable to drive and give you better road view (I'm 6 foot and they still helped) and if your like me without any metal tools you can use a hack saw |
#23 | |
http://www.quadratec.com/products/97021_00.htm $4.99 for 55W http://www.quadratec.com/products/97020_00.htm $5.99 for 100W Hope this helps! |
#24 |
I already raised my seat up that inch. What does the sway bar disconnect do?
#25 |
gives you about 5 " of FLEX
#26 |
Do I need to upgrade my alternator? I had 3 100 watt lights on 2 55 and then the normal light, head lights, runners, ect while the jeep was running and it was running high rpms. Would one out of a cop car work? Or shat would be the cheapest method or should I not worry about it? Also I need to find out where to hook my power wire up so it is not always hot like it is now, but I will look in my book unless some one knows off hand.
#27 |
Try this out: 3" lift total cost 300 with shocks (clist, buy three get on free shocks, free discos and endlinks on here)
1k even for Dana 44 with 4.56s chromolly dual pattern alloy usa shafts and arb installed 35" BFG muds 300 for 5 new wheels mounted and balanced with said 35s for 180 (local club member, and hookup at discount) $75 for disc brakes to mate to d44 Skidrow engine and oil skid 115 shipped (ebay auction with no bidders) There are deals to be had ![]() |
#28 |
Well the jeep got ripped apart tonight. It all started when I went to see about moving my e-brake. I looked at and decided I would move it when I gutted the jeep to have it rhino lined at the end of July. So I go to put my center console back and it still hits the console the cup holder and shifters are in. So I decided to remove that. That was easy and it looks a lot more like a cj
#29 |
Next update: After days of fighting with the jeep and not being able to drive it I got it drivable. Here is what I did; I moved the e-brake from between the seats to the right of the shifter. I put a new lug and all new lug nuts on. I also mounted 2 interior lights so far. I know it does not sound like a lot, but moving the e-brake was the hardest to date thing I have done. My interior lights look awesome 2! (I have pictures but photobucket is not working!!!)
#30 |
Looks good man, keep spending that money on it haha like I did and im only 19 also haha!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
