My bottle jack won't go down - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My bottle jack won't go down
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 01-07-2010, 01:18 PM   #1
Kerovick
I had to change my tire the other day, put the jack in the wrong place (******* that I am) and extended the jack fully before noticing and know I can't get it to go the whole way down. I actually had to use the jack out of my wifes truck to change my tire as I can't get mine under the jack point as it's up to high.
I have tried fully extending it again and lowering it several times and it always gets stuck at the same point (just as the last "riser" starts to go into the base).
I have also tried yelling at it, cussing at it, beating it on the ground and throwing it across the lawn. Suprisingly none of these helped resolve the issue.
Any advice?
Thanks!
Kerovick is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 01:27 PM   #2
ps49556n
This has happened to me too...the only way i could get it to work properly was to use a set of pliers and turn it back and forth until it would work on its own smoothly.
ps49556n is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 01:41 PM   #3
timberwolf0122
If you're 'jack' remains 'up' for more than 4 hours you should consult your physician.
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 01:43 PM   #4
JeepDVL45
Back in the game
JeepDVL45's Avatar
Get it drunk first....It'll go down!
JeepDVL45
"Real men hide their feelings, WHY?!
BECAUSE IT’S NONE OF YOUR ****** BUSINESS!!!!
Men do not cry. Men do not pout. Men jack you in the ******* jaw and say…thanks for comin’ out." - Boondock Saints II
JeepDVL45 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 02:58 PM   #5
JFjeld
Just a thought, but you may want to consider buying a Hi-Lift jack, rather than using the bottle jack. If you fully extended the bottle jack, it's obviously not enough. Hi-Lifts can be purchased for less than $100 and there are plenty of write-ups on the forum for mounting the jack.
01 TJ,HPD30/D44,OX,4.88,35s,1"BL,1"MML, 4.5" lift,OBA,Novak Shifter,Teraflex ESS SYE, UCF tummy tuck
JFjeld is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 03:00 PM   #6
biffgnar
biffgnar's Avatar
Not a good idea to rely only on Hi-Lift. Some tasks, like tire changing, much safer and easier to do with the bottle jack.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 03:04 PM   #7
HELMET
x2 ^^^^^^^^^^^^
HELMET is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 03:25 PM   #8
Jerry Bransford
Administrator
Jerry Bransford's Avatar
So you've tried pushing down on it with your hand as you turn the knob? Mine has gotten stuck once or twice but that took car of it.
By the way, the factory jack is more than tall enough for 35" tires and can handle 37" in a pinch too. The jack doesn't care what height your suspension lift is because it lifts the tire off the ground via the axle. Positioning the jack under a control arm or shock mount is all you need to do. I use it for my 35" tires and it isn't even close to being fully extended.
Don't use a Hi-Lift for changing tires, it's not the right tool nor is one needed except in the most unusual cases.
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
