Is my blower motor resistor bad? - JeepForum.com
post #1 of 12 Old 02-22-2015, 01:57 PM Thread Starter
Mopar03
My blower motor works in the following speeds on my 03 Wrangler: low, medium, and high. The only speed it does not work on is medium high. I am thinking I have another problem going on since the resistors are in series with one another. So could it be my resistor or something else? I replaced the resistor back in November. If I remember correctly low, and medium high would not work back at that time.
Mopar03 is offline
post #2 of 12 Old 02-22-2015, 02:55 PM
greenjp
I'd think so and it's cheap so if it bothers you change it
greenjp is offline
post #3 of 12 Old 02-22-2015, 02:59 PM Thread Starter
Mopar03
Since this is my second resistor I have been doing a little reading. Could my blower motor be going bad causing my resistor to fail? I have read that the 90's Wranglers had this problem only the wires were the bare minimum size and they would melt. My wife had a Dodge car back in the 90's and I could not keep a resistor on it. I finally bought a motor and resistor from a junk yard and she drove it a couple of years before we traded it with no more issues. I would hate to spend the money if I don't need the blower motor. Any positive input is appreciated.
Mopar03 is offline
post #4 of 12 Old 02-23-2015, 07:06 AM Thread Starter
Mopar03
^^^^Bump^^^^
Mopar03 is offline
post #5 of 12 Old 02-23-2015, 07:25 AM
ParaRigger
You can get the blower motor and resistor fairly cheap from amazon. I looked when getting the resistor at both for less than 60 shipped.
ParaRigger is offline
post #6 of 12 Old 02-23-2015, 07:28 AM
TravisHeim
I've had the same thing happen, with my previous 97 TJ and my current 2000. Replace the resistor and you'll get the other speed back. It may seem like overkill but removing the passenger seat makes it MUCH easier to do, unless you are a contortionist.
TravisHeim is offline
post #7 of 12 Old 02-23-2015, 07:41 AM
JBTJ
When my medium speed went out, it was the switch. Most of the time when you only loose on or two speeds, except for high, it's the resistor pack. But as I said sometimes it can be the switch.
Yes, the blower motor can cause your problems. But that is only because of a poor circuit design. As you have found out yourself. The blower motor begins to wear with time and starts to pull more current and because of the design of the circuit the weakest link goes first. In our case the resistor pack and speed switch fail. Some to the point where parts melt. Does this mean your blower motor is bad? No, it means the circuit needs to be redesigned. The first five years of my JEEPs life, I replaced the speed switch, mode switch and resistor pack at least 3 times each. Then I discovered if you were to install a relay between the switch and the resistor pack/blower motor it would fix the circuit design. JEEP seemed to think it would be okay to have a low rated amp switch control a high amp blower motor. As we know this does not work very long. So the fix has the switch controlling the relay which in turn controls the blower motor and all is good. This works because the relay acts like a buffer in circuit and protects the fan switch, mode switch and resistor pack from failing. 9 years ago I added the relays and up until this past fall on the original blower motor where it just quit spinning all together.
Many have done this upgrade and if you can solder takes maybe 30 minutes and less than $50 to do. It was one of the best upgrades I've done to my JEEP, well along with the headlight wire harness upgrade.
JBTJ is offline
post #8 of 12 Old 02-23-2015, 01:48 PM
Ryan0186
Get yourself a volt meter and test the volatages going to the blower on each setting. I had to replace the resistor in my 05 this past weekend. The highest speed setting on the blower was the only one that worked. 1,2, and 3 had nothing.
MANY OF US HAVE STRONG OPINIONS YET SADLY MOST OF US ARE UNINFORMED -ANDREW KEEN
Ryan0186 is offline
post #9 of 12 Old 02-23-2015, 06:35 PM Thread Starter
Mopar03
My climate control module in my Jeep was replaced back in November. So I took it out of the jeep and traded it in for a new one under warranty. Now all my speeds for the blower works. I'm concerned that the new one wore out in only three months. Seems like the blower switch should of lasted a lot longer. Wonder what went wrong?
Mopar03 is offline
post #10 of 12 Old 02-24-2015, 06:50 AM
JBTJ
Please re read post #7. You will continue to have these problems until you do the relay mod or replace the blower motor. Which you would have to keep doing every few years until you do the relay mod.
JBTJ is offline
post #11 of 12 Old 02-24-2015, 07:05 AM Thread Starter
Mopar03
I replaced the blower motor. It has a lifetime warranty. I'll consider the relay this spring.
Mopar03 is offline
post #12 of 12 Old 02-24-2015, 07:06 AM
JBTJ
Good, because you will need it. Good Luck
Lets hope you don't get a fire before you do the mod. http://www.fourwheeler.com/how-to/el...re-prevention/
JBTJ is offline
