Quantcast My blinkers just stoped working ??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My blinkers just stoped working ???
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 10-25-2007, 11:05 PM   #1
jhoff
My blinkers just stoped working, but the hazerd lights still flash ??? I dont know if they are on the same flasher selenoide. i need some quick help. thanks.
jhoff is offline   Reply With Quote
Old 10-25-2007, 11:14 PM   #2
jdragger
2 flashers.
jdragger is offline   Reply With Quote
Old 10-26-2007, 02:48 AM   #3
Jonny Jeep
Jonny Jeep's Avatar
There is only one flasher relay. There are two live feeds to the switch. A constant feed from the under hood PDC that feeds the hazard circuit and a switched feed from behind the glove box for the indicator circuit. Should be fuse 13 10A.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm#service
Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php
Jonny Jeep is offline   Reply With Quote
Old 10-26-2007, 07:57 AM   #4
jhoff
thank you for the help, i will take a look.
Glock Forum
