| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
My Bedlined Interior Pics
♂ Go anywhere: 1999 Deep Amethyst Pearlcoat Jeep Wrangler TJ Sport || CarDomain || Summer Build Thread ♂ Go fast: 2009 Buell 1125CR — Racing Red || CarDomain |
#2 |
Continued ....
![]() Done: ![]() ![]() ![]() ![]() ![]() ![]() ![]() I also used this time with the center console out to put it my leather shift boot off of the later TJs: ![]() Like I said, it turned out great as long as you do your prep work right. Got the whole coating kit from my local Advance Auto for about $55. ~J
#3 |
Good Job! 10char
The Silver Bullet 05 4.0 TJ Sport http://www.myjeepspace.com/evilspock http://4x4ham.com |
#4 |
Wahoo Wheeler
Yea I want to do that... but I'm just too lazy. Looks great!
White 01 TJ Sport 4.0 NV3550 |
#5 |
I've got that under 'things to do once I find work." Let us know how it holds up.
P.S. Nice little upgrade with the shifter boot. I went from a 97 to an 05, and the boots on the newer Jeeps are much nicer.
2005, I6, 6 Speed, RC 2.5, RC front track bar, 31" BFG A/T "Nobody is comepletly useless. We can always serve as a bad example." |
#6 |
Looks good. I am getting mine sprayed on in a month
What did you do about the snapped bolts? I snapped one side then decided to leave the other alone even though it had newer bolts on it. I bolted mine to the tub sidewall and one bolt in the floor. I just got rid of the whole shifter console and LOVE the look!
If I can get there I can wheel it! CentralMass4wd.com 1993 Ranger 2wd - dd 1999 wranger 2.5 - it gets used for something 1978 international scout - being built 1998 Cherokee sport 4.0 auto 1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/f8/restoring-57-cj5-stock-build-thread-553649/#post5168554 Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900 my build http://www.jeepforum.com/forum/f9/my-build-thread-those-us-low-budgets-550786/ |
#7 |
Looks good. As always with painting/coating whatever...prep work is critical.
I like the coatings from durabak, herculiner, etc, but I think a rubber floor would be pretty awesome. Has anyone ever thought about using rubber undercoating spray on the floor? I've only used it on little things...I'm guessing it wouldn't really stick in high-traffic areas.
2004 TJ-L with 3-4" of lift, 35's, and no money The Unlimiteds shall inherit the earth. |
#8 |
Davidosaurus
Turned out great!
David - 2002 TJ -Impact Orange buiwd-up
#9 |
The Specialist
I forget the size of the socket I used, but I found the size that fits the nuts that are fastened to the bottom of the tub and put a breaker bar on it. They snapped right off leaving me with 4 clean holes, which I filled with bolts from Lowe's.
Black 2001 Wrangler SE, stats in profile |
#10 |
I could not access the bolts under the tub there is so much **** in my way. I put in 2 bolts and was done with it!
If I can get there I can wheel it! CentralMass4wd.com 1993 Ranger 2wd - dd 1999 wranger 2.5 - it gets used for something 1978 international scout - being built 1998 Cherokee sport 4.0 auto 1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/showthread.php?p=5168554#post5168554 Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900 my build http://www.jeepforum.com/forum/showthread.php?t=550786 |
#11 |
Nice job, excellent prep work!
R.T. Many men can do what others cannot, and most of it is useless - John F. Gilbey 2006 TJ SE, Flame Red, Black Soft Top, 1/2 Doors, 6 speed manual trans, BFG ATs & Rock Crawler Black Steelies. Red Jeep Club Member #389 |
#12 | |
#13 |
Hey guys thanks for the kind words ... I really like how it turned out.
I really wish I could have sprayed it on though .. as you can see in some of the pics, the "texture" is some spots got clumped together ... it doesn't look horrible, but still. you'll BARELY use the roller brush which gives you a much better textured look ... it just doesn't fit in most places in the tj ... like between the ribs in the back i had to brush that all on. kind of disappointing but it got the job done. now i just have to replace all 4 bolts that hold those front brackets on for the rear seat and one bolt that holds down the driver's seat. i'm kind of liking running rear-seatless right now tho.
#14 |
how long total did that whole project take you to do?
97 TJ sharah Black Bf goodrich all terrains 31" |
#15 |
IYAAYAS
Just a thougth here. Did you use bolts that are strong enough to not break off in an accident? Not trying to call you out or anything. just wanted to throw it out there.
Mine: 03 TJ Hers: 01 XJ |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Bedlined Body Parts and Lights w/ pics | vanner77 | JK Technical Forum | 9 | 10-10-2009 08:09 AM |
| Pics of my New Bedlined Door Hinges | DeepSky | JK Technical Forum | 36 | 07-13-2009 05:07 PM |
| I need hard top interior pics.... | rustywrangler | YJ Technical Forum | 10 | 10-29-2007 08:14 PM |
| custom interior pics | Iquois | YJ Technical Forum | 0 | 02-12-2007 09:51 AM |
| JK 2-Door Interior Pics | wayoflife | JK Technical Forum | 10 | 10-22-2006 07:51 AM |
The time now is 07:28 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
