Quantcast My baby got wet, RAIN RAIN RAIN go away - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My baby got wet, RAIN RAIN RAIN go away
GR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Old 06-23-2007, 11:48 PM   #1
KINGZ
eak, I knew it was going to happend sooner or later, my 04 X just got a good drink of water Fridaynight, I took a nap and woke up and it was coming down heavy, I ran out and put on the trail cover.
today I was ready for the worst, I took the cover off and let it dry for a few hours in FL sun, (will dry anything out), I took it for a test drive after that, seats where just a tad damp, carpet was dry, no standing water, other than the water that came out of the dash wile driving,
blinkers did some mess up things at first, but are working fine now, but the airbag light stays on. I'm assuming this should dry out in a few days? if not where is the connector for the airbag to clean it??
KINGZ is offline   Reply With Quote
Old 06-24-2007, 12:54 AM   #2
mpyusko
I take the top down in April and don't put it up until Fall. It get rained on all the time. Heck If it's raining really hard I take it out to play in the Huge puddles. The only problem I've ever run into is the turn signal messing up. Never had the air-bag light come on, so I don't have the answer for that one. What I do suggest is you clean that Turn signal connector and reassemble it with bulb-grease to keep the water out.
One flaw(?) I've noticed with my Jeep its the defroster grate is a lot bigger than the vent. I figure this is how the water manages to get in the dash. What I did to fix the problem is, I took my old soft windows and cut them up to shield the connectors from the rain. I trimmed the pieces to fit and tucked then inside the dash to cover the turn signal relay and the rest of those sensitive connections. (I also installed a marine grade stereo.)
Good luck.
-mpyusko
_________
'97 SE Black, 4cyl/5spd, Soft top, Jeeperman Rear Bumper, 33x12.5x15 Trxus M/T's, 4" Lift, 1" JKS MML
BLACK JEEP Club V2.0 #84
Rust-Bucket Build-Ups Club Member #1
Pictures of my JeepSAVE PARAGON AP!!
mpyusko is offline   Reply With Quote
Old 06-24-2007, 02:00 AM   #3
Rocky529
Jeep
Rocky529's Avatar
Your clockspring got wet. Your horn most likely doesn't work either, and if you have cruise control, that may also not work. Remove the steering colum cover and direct a fan at it for a few hours. Usually it drys out and everything is fine.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 06-24-2007, 10:09 AM   #4
aszalan
fold your seats to keep some of the water off of them and it will also help to keep some of the water off of your steering wheel. also just drive around with the rubber drain plugs in the floor removed.
Originally Posted by shocka59 View Post
Go ahead and put a locker in the 35. I feel like it helps to keep you from breaking in certian situations.
aszalan is offline   Reply With Quote
Old 08-01-2011, 05:01 PM   #5
Brewskiskeeter
I know this thread is old but mine just got wet too, what does a clockspring look like and where is it in the column. My horn was on when it rained, thats what woke me up. I havent drove it yet so I don't know if my cruise works yet, but my wipers won't go off, lol.
[QUOTE=The_Blacksmith;11262794]you gotta be a good shot to kill someone with a .22, turning the gun sideways while your pants are falling down, and trying not to trip over your untied timberland boots dosent exactly aid people in accuracy.[/QUOTE]
Brewskiskeeter is offline   Reply With Quote
Old 08-01-2011, 06:55 PM   #6
wushaw
Rockin jeep
wushaw's Avatar
http://www.jeep4x4center.com/clocksprings-airbags/wrangler-tj.htm
wushaw is online now   Reply With Quote
Glock Forum
