My '97 TJ 'self diagnostic test' let me down! - JeepForum.com
post #1 of 6 Old 08-07-2015, 10:01 PM Thread Starter
Mr_Super-Hunky
My 1997 TJ has a built in 'self diagnostic test' which will display error codes if anything is wrong on the odometer, but mine let me down!
My jeep recently wouldn't start at all so I did the three time ignition key turn self diagnostic test. The test came up with codes '12' and then '55'. Code '12' just means battery was disconnected recently, and '55' means the test is complete. But the problem is the jeep still didn't start.
Long story short, I had a bad fuel pump relay which caused fuel pump not to come on, thereby jeep wouldn't start.
So why didn't the jeeps 'self diagnostic test' come up with a bad FP relay? I ended up doing a LOT of unnecessary work [dropped fuel tank/removed fuel pump] to eventually find the problem which could all have been avoided if the TJ's 'self diagnostic test' actually worked!
Or am I missing something here?
Mr_Super-Hunky is offline
post #2 of 6 Old 08-07-2015, 10:37 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
The OBD II system doesn't have a diagnostic code for low or no fuel pressure for your TJ...
Knuckelhead is offline
post #3 of 6 Old 08-08-2015, 01:33 AM Thread Starter
Mr_Super-Hunky
My fuel pump relay was not sending the electrical signal to the fuel pump. The circuit was not complete, however, no error code given after performing test.
post #4 of 6 Old 08-08-2015, 06:40 AM
biffgnar
biffgnar's Avatar
What self diagnostic did you do?
Romney in 2020!
biffgnar is online now
post #5 of 6 Old 08-08-2015, 06:44 AM
jay-h
Built in diagnostics only detect a limited set of issues, mainly electronic components, and even those are often misdiagnosed.
No substitute for getting in there with your tools and DVM.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #6 of 6 Old 08-08-2015, 07:19 AM
Jonny Jeep
Jonny Jeep's Avatar
The diagnostic check did work. It isn't designed to check every single piece of wiring in the vehicle. It will tell you what it can. Even when you do get codes further diagnostics are usually required by the person doing the fault finding.
The reason you unnecessarily dropped the fuel tank was nothing to do with the self diagnostic test. It was down to not following the first piece of advice given to you by Rubi4MyMrs. You even said it yourself.
Looking back, I never needed to drop the tank to begin with had I just checked the fuel pump relay first.
You are not the first to jump in the deep end without checking things out first and you certainly won't be the last.
Jonny Jeep is offline
