Quantcast My 8.8 project! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > My 8.8 project!
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 07-18-2005, 03:24 PM   #1
Testykalz
My 8.8 project!
Well, the other night I finally got around to getting my d35 out of there. I will probably be puttin the 8.8 in tomorrow! I am gonna set up the brakelines tonight and get that all figured out.
I am using RE Superflex Adj. control arms for the upper, and going to use the stock lowers.
I was going to try to use the stock d35 lines, but the 8.8 disk have the ebrake cables that loop over it, instead of this type. Anyone know how I can use this one? If I could trim back the spring some, I could try a cable thimble and clamp. That would work, but are the ZJ brake lines everyone uses just a bolt up thing? If they are, I may just use them. I might just go without an E brake for awhile, if I can't figure something out right now.
Here is the new 8.8 with M.O.R.E brackets, painted with Rustoleum Hammered Black. One complaint on the brackets, I had to drill out the shock mount holes because they were cock-eyed. A bolt wouldn't go through em. I had the rotors turned and bought the Wagner pads from O'reily's. I had 4.88's put in, and it lincoln locked! Also I am going to buy a 1350 yoke to run instead of the flange with adapter on it.
I'll try to get some more pics during the install!
[FONT=Tahoma][SIZE=1]Word up.[/SIZE] [/FONT]
[B]Black Jeep Club V2.0 Member #40[/B]
Testykalz is offline   Reply With Quote
Old 07-18-2005, 03:53 PM   #2
otisdog
Looks good and a great upgrade.
Jim
03 Sport
otisdog is offline   Reply With Quote
Old 07-18-2005, 04:51 PM   #3
MR.CLIFFORD
cut the end off the d35 brake line and loop it. Use the thimble like you thought. It should be pretty close. Hurry up and get that thing done.
MR.CLIFFORD is offline   Reply With Quote
Old 07-18-2005, 05:40 PM   #4
Reno4x4.com
You'll need 1310 yoke if you're going to run the same driveshaft.
[FONT=Courier New][URL=http://www.reno4x4.com/]RENO4X4.COM[/URL][/FONT]
Reno4x4.com is offline   Reply With Quote
Old 07-18-2005, 06:17 PM   #5
UCTJ
Looks good, I am waiting for mine to show up, itll be here on Weds, and I may slap it in that day or Thurs.
UCTJ is offline   Reply With Quote
Old 07-18-2005, 08:39 PM   #6
Testykalz
Nah, I have to get a new Driveshaft anyways so I might as well beef up the joints.
Old 07-18-2005, 11:00 PM   #7
MR.CLIFFORD
oh yea... speaking of that yoke.......
Old 07-18-2005, 11:44 PM   #8
Testykalz
Well, I didn't get the brake lines done...I went fishing instead. Anyways, I got a big list of brake stuff that I gotta get from napa/Autozone tomorrow. Then I will get the brakes set up and put it in tomorrow evening.
Andy, what about that yoke? You signed off to early for me to IM you...
Old 07-22-2005, 10:46 PM   #9
Testykalz
Well, Got it in and got to looking and I am gonna have to get an adjustable rear trackbar. My left upper spring perch is about an 1/4" from touching my brand new tire! ha... Ran into another problem with my brakeline, I had a custom one made and the guy put the fitting into a vise(i suppose) to fix it and the hole is now egg shaped. Taking it back tomorrow to get it fixed IF they are open on saturday. Other than that, everything is going good.
Old 07-22-2005, 11:11 PM   #10
Rogi
Concerning the e-brake:
http://tony4aro.myjeeppage.com/photo3.html
Dont forget the loc-tite on the threads.
Rogi is offline   Reply With Quote
Old 07-22-2005, 11:18 PM   #11
Testykalz
Thanks, I went ahead and just got ebrake cables from a rear disc ZJ. They just go right into place.
Thanks though! That's what I was trying to do..but my d35 ends didnt look like that?
Old 07-23-2005, 05:47 AM   #12
penguinland
The e-brake is a great idea, I was wondering what I was going to have to fab up because I thought the ZZJ brake lines were too expensive for what you get. I am working on getting the brackets welded in today and I have to get the HP D30 painted. I'm seeing the finish line
Bone Stock
penguinland is offline   Reply With Quote
Old 07-23-2005, 01:09 PM   #13
Rogi
Test - I think we had to cut some of the spring off thats around the cable, other than that it was bolt in.
Penguin - 8.8 is by far the best dollar for dollar mod out there. Def worth the effort
Glock Forum
