My 5.9l Magnum Swap - JeepForum.com
post #1 of 22 Old 05-04-2011, 07:32 PM Thread Starter
SGjeeper36
My 5.9l Magnum Swap
Well, I figure I might as well start a thread on my swap. Haven't started yet, just need to get a few more parts and I'll be set. If only someone would buy my 4.0 then I could get started. (Hint hint! Check the classifieds!)
I got the motor from a '96 ram with a manual transmission. I'll be reusing my nv3550, so I finally picked up a bellhousing from a dakota with the 3.9l and ax-15 (took forever to find). I spoke with Evan at Backwoods and he steered me in the right direction for a clutch to match everything. The clutch kit is for a 99 Dakota with the 5.2.
Since I have a '96 motor, guy who I bought it from told me it was a '98 and I trusted him enough to not check the block casting, I will be running all new gauges. So far I have the fuel level, oil pressure, and engine temp. Still need to get the tach and speedometer. I'm going to cut a piece of aluminum and use the factory cluster as a template and go from there. Should look pretty good when I get done, or so I hope.
The motor came with starter, flywheel, complete wiring harness except for two plugs that were cut (but I won't need em anyways), all new power steering lines still in the box, and all the hoses still attached. I ditched the factory air box, didn't think it would fit under the hood, plus it's just so bulky. I just picked up a new throttle cable from the stealership yesterday. Gonna run an autozone special electric 16" fan. I'm not sure how well it will do, if it doesn't work out then I'll just get a flex-a-lite one. I still need to get block hugger headers, and a CPS, then I should be all set to go.
The hardest part will be the wiring, of course; however, I have a friend thats gonna help me with that part so it should go pretty smoothly with two people tackling it. Plus, it will be good to have someone to make sure I'm not splicing in the wrong wires!
More to come soon!!
SGjeeper36 is offline
post #2 of 22 Old 05-04-2011, 07:42 PM
pcoplin
pcoplin's Avatar
You know that if you get a 98+ PCM it shoulod work with your gauges? Just would need to change the wiring on the transmission relay, the alternator, and get an electric oil pressure sender. Be cheaper than buying all new gauges...
pcoplin is offline
post #3 of 22 Old 05-04-2011, 07:51 PM Thread Starter
SGjeeper36
True, but its a good excuse to switch out the factory cluster. Plus, I got the hook up on those gauges from a buddy of mine.
post #4 of 22 Old 05-04-2011, 08:38 PM
rda616
You can use a clutch fan off a v8 zj 93-98 . It's a perfect fit for the 4.0 fan shroud . I'm using this one on mine and it doesn't even attempt to over heat.
rda616 is offline
post #5 of 22 Old 05-04-2011, 08:52 PM
rda616
Is that a non egr engine? And what plug ends are on the harness . My 98 harness has different sensor plugs then a 96 has! The block casting doesn't really tell the whole tale. They could have a reman in it.
rda616 is offline
post #6 of 22 Old 05-05-2011, 05:51 AM Thread Starter
SGjeeper36
It has egr. Which plugs are you specifically talking about?
As for the fan, the motor came without one and Evan kept pushing I would be happier with an electric, so I figure why not try it. I don't think it will make a difference other than being able to turn it off for water crossings.
post #7 of 22 Old 05-05-2011, 10:11 AM
rda616
If its egr it's likely a 96 . If you are going to waste the money on a cheap electric fan, then buy a good one anyway start off with the zj fan. It should cost about twenty bucks from a you pull it type yard and save you money to get things you really need to get your jeep running! Also be sure you got the right year accelerator cable. They changed the linkage on the tb in the mid 90's. Also shop ebay for a v8 swap radiator. I got mine for 230 shipped.
rda616 is offline
post #8 of 22 Old 05-05-2011, 10:49 AM
mschviuz
Let the fun begin....
mschviuz is offline
post #9 of 22 Old 05-06-2011, 03:31 PM
Erik T.
Erik T.'s Avatar
This is awesome. Good luck!
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline
post #10 of 22 Old 05-19-2011, 07:06 AM Thread Starter
SGjeeper36
So I started my swap! Had a buyer for my old motor finally. Got it pulled on Friday and sold it Saturday. By Sunday I had the motor mated to the transmission for a test fit. Had to do some firewall clearanceing. Got the motor mounts welded on Monday night. Dropped it into its permanent location on Tuesday. Started the wiring then. So far I've got the hoses hooked up, besides the radiator. The throttle cable is hooked up, and my new headers on. My buddy came by to help me finish the wiring last night. We got it to turn over, but didn't start. It didn't start because the crank posistion sensor isn't hooked up. Plus the new fuel line I got from a junkyard dodge must be damaged at the frame side spring lock. I thought it was clipped in but nope. Had gas spraying out from under the jeep. Still can't get it clipped in. Today I'm going to get some oil, oil filter, new cps (auto parts store gave me the wrong one), clean up the wiring, and mess with the fuel line. Hopefully have it started up by tonight. I will upload pictures later and go more in depth into some things, but for now, back to the garage!
post #11 of 22 Old 06-05-2011, 09:29 AM Thread Starter
SGjeeper36
So, got the motor running after loads of problems. Still isn't driveable. Taken it for test drives and worked out the small bugs. Now its stalling out after a whille. Got exhaust put on it the other day. The o2 sensor is hooked up but not in the exhaust, forgot to tell them to weld in a bung, so its running rich and flooding the engine. Should be able to fix it today and drive it around. I must say, this Jeep sounds amazing.
Everyone says the wiring is fairly easy and straight forward, which it kind of is, but its by no means easy. Lots of headaches.
The first two test drives I ended up on the side of the road. The first time my powersteering return line popped off. Second the lower rad hose had a pinhole leak that turned into a gushing leak. After the exhaust shop it stalled out and wouldn't start back up on the highway, ended getting towed home by an ambulance
post #12 of 22 Old 06-05-2011, 01:23 PM
DerekXJ
So freaking awesome!!!!!!!!!!!!!!!
Can we see some pics of the motor installed in the jeep?
DerekXJ is offline
post #13 of 22 Old 06-06-2011, 04:32 AM Thread Starter
SGjeeper36
Sorry for the huge size, photobucket won't let me resize any images. Ill post more photos of the swap when I get home today.
post #14 of 22 Old 06-06-2011, 05:54 AM
T-Jay
T-Jay's Avatar
Huba huba
T-Jay is offline
post #15 of 22 Old 06-06-2011, 06:54 AM
LiveAndLearn
I wanna see a 4wd burnout.
LiveAndLearn is offline
magnum engine swap Arcticcat843 TJ Wrangler Technical Forum 17 09-14-2015 01:35 PM
5.9L Magnum Swap? Diffcult? rastaangel TJ Wrangler Technical Forum 7 02-14-2013 07:06 PM
Swap a 3.9 magnum into the yj Russell_Goodall YJ Wrangler Technical Forum 18 10-28-2011 07:30 PM
5.2L Magnum Swap - What's needed? Rynfw100 YJ Wrangler Technical Forum 26 05-06-2011 08:30 AM
Looking into 4.2 to 318 (5.2) Magnum Swap lt_liverdamage YJ Wrangler Technical Forum 6 01-11-2010 10:35 AM
