my 4.0 s engine is flaking into pieces - JeepForum.com
post #1 of 7 Old 08-22-2013, 05:29 PM Thread Starter
asphaltcowboy56
my 2000 TJ's 4.0 s engine is rusting into small pieces. Their are no oil or coolant leaks. It runs fine and the coolant plugs are holding and so are the bolt holes around the mounts ,the area around the oil pan is thinning but still hold the pan flush. I am worried that like body rust eventually the coolant walls will start to leak .The cylinder head does not show any of this condition, what is up! its bad!
asphaltcowboy56 is offline
post #2 of 7 Old 08-22-2013, 07:30 PM
CommonSense
Sounds a little dramatic. No pics so I can only go off what you said and what I know. Surly you are not talking about the block or head, if those were "rusting into small pieces" I would be a monkeys uncle! Sooo... are you talking about surface corrosion? maybe the edges of the oil pan? maybe oil pan itself? ( i.e more details/ pics needed.) Mating surfaces of different alloys and metals can and in most cases will encourage corrosion too fyi...
CommonSense is offline
post #3 of 7 Old 08-22-2013, 08:21 PM
Turfzilla
My block is really rusty and flakey. I'll run until I can see oil thru the side if it
03 Rubicon, NV 3550, 4" LA, UCF TT, Rear Rock Jock 60, Ultimate 44 w/Artec Truss/gussets and RCV shafts and 37" Irocks
Turfzilla is offline
post #4 of 7 Old 08-22-2013, 09:01 PM
jjvw
jjvw's Avatar
Both you and the OP should take pics of your rusty engines. Call me naive, but this sounds weird.
2003 Rubicon
jjvw is online now
post #5 of 7 Old 08-22-2013, 09:13 PM
ShogunTJ04
1976 CJ5
If you're talking about the surface finish, mine did it too, but I have a 2in body lift and I like driving through mud and puddles at high speeds, so it was bound to happen eventually. It's just a cosmetic finish, so unless there's any cracks or damage, just get some POR15 and coat the whole thing. Then paint it with whatever high-heat paint you want. I did orange.
That's not death wobble, the roads in PA are just *that* bad.
Stock 4cyl and 35's=Rock Crawling like a bus!
ShogunTJ04 is offline
post #6 of 7 Old 08-22-2013, 10:20 PM
joe108
pictures...
joe108 is offline
post #7 of 7 Old 08-30-2013, 11:49 PM
CommonSense
...no offense but POR-15 Probably isn't the fix for the engine block. I have to imagine the OP's standards are like mine and when I see my beloved have cancer (even in the most minor of forms...) I can panic! Honesty being Policy...: ANY block rust CANNOT be of "terminal concern" OP. It would have to be exposed to salt water daily and be a CJ in order to be of any "possible" concern... I hope this helps your "espirit-de-jeepness". If not, fellow jeepers PLEASE console our fellow jeeper!
