My 2003 Wrangler Idles From 1000 RPM to 2000 RPM whats wrong? - Page 2 - JeepForum.com
post #16 of 23 Old 05-31-2012, 10:42 AM Thread Starter
erics1019
how can i tell if they are leaking! and also i know it may sound stupid but the manifold is where the header attaches correct can you send a pic of the manifold and cables i would greatly appreciate it and also do i need to leave the jeep running?
erics1019 is offline
post #17 of 23 Old 05-31-2012, 10:45 AM
rondenzer
Get a can of spray carb cleaner and with the engine running spray all of the vacuum lines and hoses, if the idle drops down then you have found your leak. If no leak there then spray around the intake manifold, again if the idle drops you have found your leak. Mine was a rotten hose on the fuel vapor purge valve, quick fix once located.
rondenzer is offline
post #18 of 23 Old 05-31-2012, 10:53 AM Thread Starter
erics1019
you say spray it on the hoses and find your leak do i have to disconnect the hoses and spray them or spray them attached and also how will that drop the idle if i spray the hose i am confused again i am sorry i never done this exact thing before i am sure its easy i just want to be sure before i start it and is carb cleaner the same as TB cleaner thanks. can someone send pics of the manifold and hoses and how many hoses are hooked up normal to the manifold thanks!
post #19 of 23 Old 05-31-2012, 10:54 AM
LittleBluE
Carb cleaner should just be called problem diagnoser. I never use it on carbs looooool
LittleBluE is offline
post #20 of 23 Old 06-01-2012, 07:31 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You're looking for leaks where the various vacuum hoses are connected. Leave the hoses connected and after starting the engine, start spraying the hoses where they connect and if the cleaner gets sucked in through a vacuum leak, the engine RPMs will change.
Jerry Bransford is offline
post #21 of 23 Old 06-04-2012, 10:35 AM Thread Starter
erics1019
ok so this weekend i took the TB off and cleaned it really well and i took the AIC plunger out and cleaned it as well but my engine still revs up around 1500 rpms what else could be the issue any one have any ideas thanks!
post #22 of 23 Old 06-04-2012, 10:44 AM
Necko2529
Necko2529's Avatar
Have you looked for/located a vacuum leak?
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #23 of 23 Old 06-04-2012, 10:46 AM Thread Starter
erics1019
no i have not how can i do that again please describe in details thanks!
idle issue , jeep , nuetral , wrangler tj
Help find out whats wrong with my Wrangler YJ ringer82 YJ Wrangler Technical Forum 3 07-10-2011 03:25 PM
What's Wrong w/ My 2003 Jeep Wrangler Sport v.31"tires KhakiSport03 TJ Wrangler Technical Forum 9 04-29-2010 03:35 PM
Tj Idles at 1000-1200 before settles at 750? willieash TJ Wrangler Technical Forum 9 04-11-2010 09:13 AM
Help MY Climate control on my 2000 Wrangler has slowly stopped working. What's wrong? bufordpusser123 TJ Wrangler Technical Forum 2 10-15-2006 05:51 PM
90 YJ idles between 1500-2000 lXl Rebel Wrangler lXl YJ Wrangler Technical Forum 3 07-07-2002 11:19 PM
