My 2003 Wrangler Idles From 1000 RPM to 2000 RPM whats wrong? - JeepForum.com
post #1 of 23 Old 05-31-2012, 08:24 AM Thread Starter
erics1019
hey jeep just recently started idling high. it does it about 80 percent of the time. when i turn it on it idles around 1000 rpm to 2000 rpm when i put it in first and let go the clutch it seems to go do down and it drives fine while driving but when i idle in neutral or have the clutch pressed it idles high anyone have any ideas what could be going on. i have replaced the TPS sensor and all 4 O2 sensors as well already! and there is no check engine light on what else can it be help please thanks!
erics1019 is offline
post #2 of 23 Old 05-31-2012, 08:43 AM
wytewolf00
Go to Advance Auto Parts and use their scanner anyway. Just because the CEL isn't on, doesn't mean that a monitor is throwing a code somewhere.
You might want to take apart the TB and give it (and everything attached to it) a good cleaning.
Also, please fill out your profile...hard to see what we're dealing with here...
Zombie Outbreak Response Unit #295
wytewolf00 is offline
post #3 of 23 Old 05-31-2012, 08:52 AM Thread Starter
erics1019
i was thinking of doing that but i was scared when i was reading the write up and it says the gasket for the AIC do i need the gasket or can i re-use everything i take off will i need anything new?
post #4 of 23 Old 05-31-2012, 09:04 AM
LittleBluE
Clean the IAC valve. That can make it idle rough. Hell clean out your throttle body and you'll probably fix the problem
LittleBluE is offline
post #5 of 23 Old 05-31-2012, 09:07 AM Thread Starter
erics1019
i want to do that but i was reading a step by step guide and it said to use a new gasket or gasket sealer will i need that or can i just take the TB a part clean it and put all the original stuff back on?
post #6 of 23 Old 05-31-2012, 09:11 AM
gotmudd1
I had the same problem awhile back. Cleaned TB and senors and no problems since. You can reuse the gasket if it comes off in one piece and in good shape. No need to use sealer on the TB. Good luck!
97 Wrangler: 4.0L, 5 speed, BB, 31's KM2's, CAI, Cat-Back Exhaust
gotmudd1 is offline
post #7 of 23 Old 05-31-2012, 09:19 AM
wytewolf00
I ripped the IAC mount gasket when I tore my TB apart, but used Permatex Copper to seal it up on the re-install. Been fine since. I also keep a sheet of adhesive-backed gasket material in the garage, in case I need to make one...
Just be careful and don't over-torque the bolts. Clean and scrape every surface, spray it thoroughly with TB cleaner and be sure to get into the small spots. I used Q-tips and an old tooth brush for most of it, and a razor blade to scrape oxidation off of the surfaces.
post #8 of 23 Old 05-31-2012, 09:20 AM Thread Starter
erics1019
thanks i am going to give it a shot this weekend thanks!
post #9 of 23 Old 05-31-2012, 09:21 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A high idle like that is more often caused by a vacuum leak. Cleaning the IAC won't hurt but has any work been done on the engine recently, like on the intake manifold or exhaust header? Work like that can easily cause a vacuum leak which invariably causes high idle RPMs.
Getting
Jerry Bransford is online now
post #10 of 23 Old 05-31-2012, 09:23 AM Thread Starter
erics1019
no nothing has been down for almost a year to the engine. if i bring it to a shop can they find the leak if i have one and how much would they normally charge i don't think i would be able to find a leak and fix it?
post #11 of 23 Old 05-31-2012, 11:07 AM
LittleBluE
Jerry that totally slipped my mind.
Vaccum leaks can very easily cause your problem.
LISTEN to jerry. He's the man.
post #12 of 23 Old 05-31-2012, 11:09 AM Thread Starter
erics1019
is a vacuum leak something i am going to have to bring it in to a shop to have them find and fix and is it expensive?
post #13 of 23 Old 05-31-2012, 11:29 AM
Necko2529
No. It could be as easy as sticking a hose on a corresponding spot on the intake manifold.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #14 of 23 Old 05-31-2012, 11:34 AM Thread Starter
erics1019
i am confused what you mean sticking hose? what hose and how will i know which hose? sorry i am some what mechanical and stuff but i actually have never done this before!
post #15 of 23 Old 05-31-2012, 11:40 AM
Necko2529
It simple, open up your hood and start poking around the intake manifold and you will find hoses going into intake manifold. Make sure those hoses are all attached and not dry rotted or leaking...
idle issue , jeep , nuetral , wrangler tj
Help find out whats wrong with my Wrangler YJ ringer82 YJ Wrangler Technical Forum 3 07-10-2011 04:25 PM
What's Wrong w/ My 2003 Jeep Wrangler Sport v.31"tires KhakiSport03 TJ Wrangler Technical Forum 9 04-29-2010 04:35 PM
Tj Idles at 1000-1200 before settles at 750? willieash TJ Wrangler Technical Forum 9 04-11-2010 10:13 AM
Help MY Climate control on my 2000 Wrangler has slowly stopped working. What's wrong? bufordpusser123 TJ Wrangler Technical Forum 2 10-15-2006 06:51 PM
90 YJ idles between 1500-2000 lXl Rebel Wrangler lXl YJ Wrangler Technical Forum 3 07-08-2002 12:19 AM
