Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Moto Alliance Viper Elite 8,000lb Winch Giveaway!
Go Back   JeepForum.com > Models > Wrangler Forum Group > TJ Technical Forum
Jeep Registry Register FAQ Mark Forums Read Search Members
Old 03-29-2009, 08:15 PM   #16
Unlimited04
Unlimited04's Avatar
any side shot pictures and/or pics from the cowl? whats its mounted to?
looks great, this might be my new favorite CAI.
Unlimited04 is online now   Reply With Quote
Old 03-29-2009, 09:37 PM   #17
George Dickel
Restoration Complete
George Dickel's Avatar
I'll take some more pics tomorrow. Right now it's not mounted to anything. The rubber horn is really the best part of this thing. Keep in mind that I am not "running" just yet. I'm still a few weeks away on my restore which explains why I'm not in a big hurry. You'll notice in the picture that there is no radiator or battery installed. No need for them to be in my way just yet.
Anyway, I plan on coming in from the firewall with a simple strap of some sort that will cradle the housing. I pulled the horn from inside the cowl until it is SUPER snug and it is pretty solid. This housing is not as heavy as it looks. While I do plan to support it in some manner, the end of the horn is belled out so it will never come out of the cowl unless you make your firewall hole larger.
Like I said, I'll snap some more pics soon and we can all tweak this thing together. BTW, I tossed the old Fram Air Hog (K&N type) filter I ran back in 04 and replaced it with an OEM style Wix filter for $19.
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Venom Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Screamin' Demon Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust.
Balanced Rotating Assembly
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline   Reply With Quote
Old 03-29-2009, 11:46 PM   #18
jeepwrangler97
it's done, I've been waiting for a couple of days, haha, looking forward to more pics
jeepwrangler97 is offline   Reply With Quote
Old 03-30-2009, 05:40 PM   #19
George Dickel
More pics...
Here are the promised/requested additional pictures.
View from the cowl:
Drivers side cowl:
Passenger side - side view:
Driver's side - side view:
And finally...laying on a creeper under the motor looking up the firewall:
Light modifications
Old 03-30-2009, 08:00 PM   #20
George Dickel
Bracket
I think when its all said and done, I will use a bracket similar to the one used in the Buick Airbox write-up. I'll get to that in the next couple of weeks. In the meantime, be my guest to improve upon my simple design!
Light modifications
Old 04-09-2009, 10:15 AM   #21
jeepwrangler97
wow, I love this intake, this might be the one I end up using
Old 09-23-2009, 09:48 PM   #22
George Dickel
update
I've been running as a daily driver since July and have not made or needed any sort of bracket. I removed it in August and really had to pull on the rubber horn to get it out of the firewall. I've been very impressed with it.
Light modifications
Old 09-23-2009, 09:56 PM   #23
lumpster
Functional Jeepaholic
lumpster's Avatar
did you remove it perminently? Does the jeep run any smoother, or does it idle any better since its not breathing hot air?
there's very little that is more permanent than a temporary solution
IMPACT ORANGE JEEP CLUB MEMBER #32
lumpster is offline   Reply With Quote
Old 09-23-2009, 10:01 PM   #24
George Dickel
Sorry, I should have elaborated. I removed it to get it out of my way so I could get to the nuts on the firewall that hold the HVAC box. I put it back after I reinstalled the dash. No you don't have to do that but it is easier.
As for part 2 of your question: I have never run this TJ in any other manner that the current build so I don't know. I did this because I desired true cold air and had the Mustang cannister sitting around. Also, I did this because I increased displacement (see my signature line for engine info). I doubt this would do anything for a stock motor. I am not stock.
Light modifications
relocate evap cannister 2005X TJ Technical Forum 26 11-18-2009 08:11 AM
A/C Vacuum Leak, NOT the Cannister Morris4x4Center JK Technical Forum 0 09-21-2008 07:14 PM
charcoal cannister dcaddell JK Technical Forum 11 03-30-2008 07:51 AM
how do you remove the AC cannister? cincytj TJ Technical Forum 4 01-18-2007 12:30 PM
Need Evap Cannister 89 YJ Scurv YJ Technical Forum 1 12-12-2003 06:17 AM
The time now is 07:29 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
