Quantcast Mustang GT Air Cannister - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Mustang GT Air Cannister
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-23-2009, 11:26 PM   #1
George Dickel
Restoration Complete
George Dickel's Avatar
I am using my OEM Mustang GT Air Cannister as a homebrew Jeep CAI. The following pictures detail the components. I had to take a break from Jeep restoration the past two days to build a "tea cup" prop for my daughter's high school choral show. Anyway, I've based my build from the thread here that the guy used an Apollo CAI going thru the firewall into the cowl area. I will insert the rubber "horn" of the Stang unit thru the firewall. The inside diameter is about 3 1/2" which is more than adequate for air flow. More pics to follow when the install is complete. I would think this part would be easy to come by since it is usually the 1st bolt on performance item in the Mustang world.
This part below was $19.99 at Oreillys and is expandable/bendable. It answered any question/concern I had.
The stock air housing trimmed down to retain the PCV...
The rough unit awaiting installation
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Venom Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Screamin' Demon Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust. Balanced Rotating Assembly.
Yeah, I built it!
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline   Reply With Quote
Old 03-23-2009, 11:32 PM   #2
WillysEdition04
Can't wait to see it finished. Way to be resourceful!
04 TJ Willys Edition 41MB-04TJ #4913
The WILLYS Edition Owners Group
Your post count does not represent your knowledge, it represents your use of free time.
WillysEdition04 is offline   Reply With Quote
Old 03-24-2009, 01:12 AM   #3
jeepwrangler97
Wheel Weber
jeepwrangler97's Avatar
Thanks for the link, I can't wait to see this installed
jeepwrangler97 is offline   Reply With Quote
Old 03-24-2009, 02:32 AM   #4
mudb8
want it rite or rite now?
mudb8's Avatar
what year mustangs use that housing?
I've been cutting down winstar/explorer and escort boxes.. looks like they use about the same element.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 03-24-2009, 07:23 AM   #5
George Dickel
Mine is an '04. That model year is basically the same from 99-04.
Yeah, I built it!
Light modifications
Old 03-24-2009, 09:21 AM   #6
Unlimited04
Unlimited04's Avatar
added to the CAI FAQ Thread.
Unlimited04 is offline   Reply With Quote
Old 03-24-2009, 02:09 PM   #7
Slithering_Joe
From 1994 thru 2004, they are very similar (V6 & V8)
4.0L TJ 5.7L CTS 3.7L KJ
Slithering_Joe is offline   Reply With Quote
Old 03-24-2009, 02:16 PM   #8
mudb8
mudb8's Avatar
thanks guys, looks like less work from the start and the same result in the end..
Old 03-24-2009, 03:31 PM   #9
pwcracer
94's and 95's were still the 5.0 for a V8, in 96 it switched to a 4.6 v-8
You may want to check that the intake is still similar.
pwcracer is offline   Reply With Quote
Old 03-25-2009, 07:58 AM   #10
Slithering_Joe
I had both a '94 & '96 Mustang and the '94/'95 style looks like it would make for an awkward looking modification. The Mass Air Flow sensor was mounted inside the airbox for the '94/'95 cars. There is a protrusion on the side of the air box would it look ugly. The '96+ cars have the MAF sensor external to the airbox.
See below:
'94/'95
'96+
Old 03-25-2009, 01:20 PM   #11
George Dickel
The '96 Cobra shown there is the identical setup as my '04. That should be great news for availability. Not too many Stangs out there still have that original air can. Hopefully those guys saved them like me. As for the Mass Air Flow sensor, when unbolted and out of the way, the flexible hose I got from Oreilly's inserts from the inside and fits the hole very snug.
Weather permitting, I should be finished tonight. I drilled my hole through the firewall last night between rain showers but it is 3 1/8" and I need maybe another 1/8th on top/bottom. The rubber "horn" is very flexible but is not completely round. That part doesn't matter so much but the hole is just too small.
Yeah, I built it!
Light modifications
Old 03-29-2009, 07:26 PM   #12
George Dickel
Complete
I have completed the modifications and installed the new homebrew CAI. I recommend using a 3 1/2" holesaw. I had to grind the bejesus out of the firewall since I used the 3 1/8" saw (what I had laying around). Because the "horn" is contoured and becomes larger as it approaches the filter, the larger the firewall hole, the closer the housing is to the firewall. That, by the way, is preferred to keep from interfering with the dipstick or oil fill. I still may tweak it some but I am very pleased.
Yeah, I built it!
Light modifications
Old 03-29-2009, 07:29 PM   #13
George Dickel
Also of note - I trimmed the expandable tubing by about 1/3 of it's length.
Yeah, I built it!
Light modifications
Old 03-29-2009, 07:38 PM   #14
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
How's the horn fitting into the hole? Anything to keep it in there where it won't slide out or rattle?
I like this setup and might just steal it. However I'd look into taking a 3" LED light grommit and stuffing the horn into it.
I really am impressed.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline   Reply With Quote
Old 03-29-2009, 08:01 PM   #15
George Dickel
The horn is rubber, stiff, and moderately flexible. You just cram it into the hole until it stops and its "in" for good. You really have to yank on it to get it out! I have not even permanently mounted the housing yet.
One word of advice: I removed the 3 factory attachment points. The housing is strong enough so that you can drill a hole in order to attach some sort of bracket if needed.
Yeah, I built it!
Light modifications
Glock Forum
