Must have winch accessories? - JeepForum.com
post #1 of 6 Old 07-15-2010, 08:36 PM Thread Starter
viperbluelx
I'm getting a XD9000i winch tomorrow. What else do I need to get to make it functional(it comes with a winch plate)? What do I need as far as the charging system?
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #2 of 6 Old 07-15-2010, 08:37 PM Thread Starter
viperbluelx
Also my Jeep has a 2.5" RC lift and already sits 3/4" lower in the front than the rear. How much spring spacer you think I'll need to get it to sit level after the winch install?
post #3 of 6 Old 07-15-2010, 08:44 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
GOLENJEEPTJ is offline
post #4 of 6 Old 07-15-2010, 08:45 PM
GOLENJEEPTJ
Wait until after your install... then you will know! Your charging system should be fine!
post #5 of 6 Old 07-15-2010, 08:52 PM
rs4race
If you still have a regular battery you will want to get a deep cycle. You can use a marine deep cycle, same thing as an optima yellow top, but half the price.
Other then that, gloves and a tree saver minimum.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #6 of 6 Old 07-15-2010, 09:03 PM
Jtrux
I recommend a hand throttle control. It helps ALOT imo. If not and you have to do some heavy winching you will have to sit in the front seat and apply some throttle manually which sucks especially when you're by yourself and you have to be outside the jeep.
Also just like the poster before me, gloves are absolutely necessary and I always have a flashlight too just in case you get caught out at night.
RE1000 - HAND THROTTLE - Rubicon Express
As far as what to do about the rake, I don't have a lift but I have a 1.75 spacer on the front of mine and it sits slightly unlevel so you might think about trying a RC 4 inch coil for the front, I bet that would get you level.
Jtrux is offline
battery , charging , level , leveling , winch , winch accessories
winch accessories fireshadow Wrangler General Discussion 2 05-05-2009 11:33 AM
where to buy JK accessories? arkansasJK JK Wrangler Technical Forum 7 04-07-2009 09:26 PM
Best accessories coloradokid JK Wrangler Technical Forum 14 02-10-2008 02:16 PM
RB1 and Accessories.... AppleMacGenius TJ Wrangler Technical Forum 5 10-09-2007 01:34 PM
Accessories... bamakrw YJ Wrangler Technical Forum 1 02-13-2004 09:49 PM
