Multiple problems all in a row! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Multiple problems all in a row!
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 12-26-2014, 12:45 PM   #1
Dans95ZJ
So:
Lower radiator hose broke.
Fixed it pretty quickly and now I have no heat.
And also I'm stalling for no reason I can think of.
I changed out the water pump, radiator, and thermostat about 2 years, 10,000 miles ago.
Why am I stalling? Any ideas to keep me busy this weekend?
Only in My Jeep!
Dans95ZJ is offline   Reply With Quote Quick reply to this message
Unread 12-26-2014, 12:48 PM   #2
MisfitSeven
MAIL Crawler.
MisfitSeven's Avatar
Was your heat working prior to the hose failure?
Mail crawling.
MisfitSeven is offline   Reply With Quote Quick reply to this message
Unread 12-26-2014, 01:01 PM   #3
Dans95ZJ
Yes it was. But I have to say it never got as hot as my old YJ!
I flushed the whole cooling system after I replaced the hose using the Prestone in-line flush (garden hose connector) and theres a lot of brown crud that came out.
Flushed again the next day and it's pretty clear.
Now I'm wondering if any of that crud clogged up the thermostat. Might have to pop the cover off again and replace the thermostat.
I really can't understand why it stalls now.
Only in My Jeep!
Unread 12-26-2014, 01:17 PM   #4
danielbuck
Is the engine over heating?
Daniel Buck - [URL="http://www.danielbuck.net"]www.DanielBuck.net[/URL] - [URL="http://www.dnsfail.com"]www.DNSFAIL.com[/URL]
danielbuck is offline   Reply With Quote Quick reply to this message
Unread 12-26-2014, 01:22 PM   #5
Dans95ZJ
Not overheating, runs hot - over 210 - then jumps down to 200.
Only in My Jeep!
