Multiple cylinder misfire!!! - Page 5 - JeepForum.com
post #61 of 71 Old 10-24-2013, 07:45 PM Thread Starter
SpecialTwinky
Haven't posted in a while because I have been trying to figure out this jeep. But the misfiring is still there. It is every cylinder except for 2 that misfires. I also found that now the tranny doesn't go form second to third gear very nicely. It starts to jerk and go all crazy when it is time to shift. I can't tell if it does shift but I am pretty positive that it doesn't shift into third because I can't get it to go any faster. Could this cause the engine to misfire or not necisaraly. And also, can the computer be causing the misfires? Would it be bad?
SpecialTwinky is offline
post #62 of 71 Old 10-24-2013, 09:08 PM
IrishDude
I had the same issue with my TJ. Throwing p300, p301 codes. Bring it to a shop and they cleared the codes and what not. But they never really fixed it, just put a bandaid on it i guess. After the second try with this shop, I tried a different shop. They replaced the cat and and everything up to the headers. Fixed it. Jeep runs like new. Just my 2 cents....
IrishDude is offline
post #63 of 71 Old 11-09-2013, 05:12 PM
squirt
Yesterday driving home A1A along the coast at around 35-40 mph started running rough and seemed like it was running, barely, on 3 cylinders, CEL flashing off and on, then steady on. p0301 and p0305 came up.
It's dark so I quick disconnect the battery and call it a night.
Up this morning and start with spark plugs. all looked OK, only 4-5k miles old.
Engine was running fine up until a week ago. seemed like the typical jeep BS.
Had noticed at about the same time a low tone vibration. It became more pronounced up until last night. got underneath and started hitting everything with a rubber mallet trying to find the source of the vibration. Found it....
The flange bolts that hold the exhaust to the header were very loose. luckily everything must have just started to get loose as it was easy to tighten all four bolts using 3/8"drive short socket with one 10" and three 3" extensions.
Made it easy to work around the cats and get the socket on the bolt head.
Runs great. Figure the O2 sensors must have read the exhaust leak as a running lean issue and basically enriched the fuel ratio, choking the engine with fuel causing the misfire codes.
squirt is offline
post #64 of 71 Old 03-05-2014, 10:12 AM
02MoabTJ
Hello Jeepers, I'm pulling this thread back up because I have had the same problem for almost a year now, not having fixed the problem with replacing the CPS, TPS, Coil, Plugs, Fuel pump, and cleaning the throttle body with combustion chamber cleaner (MOPAR). My mechanic (former Chrysler service manager) has pointed out, and I saw this, that the CEL blinks codes 0300, 0301, 0302, etc at will exactly at 2,250 RPM to 2,500 RPM if kept there steadily for more than 10 seconds. Unbelievable... Even worse, we live in Ca. and smog is due early May!
Totally stock '02 TJ 4.0 3.73 30x9.50 hard-top 38K mi (Fresh Meat lol)
OK that was 3 years ago...
5.5 RE Long-arm Tri-link, 4.56 gears, 35" MTRs, LoD Signature Tire-Carrier with Jerry-can holders and Safari-rack, Grande30 upgrade front / G2 Dana 44 35-spline with Disc rear same 4.56 gearing - ARB on all.
02MoabTJ is offline
post #65 of 71 Old 03-06-2014, 07:10 PM Thread Starter
SpecialTwinky
Sorry haven't been on in a while. Figured out that my issue is with a grounding issue. We figured this out by changing spark plugs and looking at the order that it is misfiring and it was different. The ground issue is with either the computer, tps, or the crankshaft position sensor. We are almost certain that the sensors are fine so we are going to take the jeep to the dealership and have then replace it. Will report back when we get it done.
post #66 of 71 Old 03-06-2014, 07:41 PM
jkp
I don't remember if this was mentioned already or not, but it just came to mind:
http://en.allexperts.com/q/Chrysler-...ee-problem.htm
'92 Islander
'06 Rubicon
jkp is offline
post #67 of 71 Old 03-31-2014, 04:49 PM
02MoabTJ
no results yet!
New copper plugs, coil rail, TPS, Cam PS, Crank PS, misfire TSB performed twice, new fuel pump... Still getting P0300, 01, 02, 05, 06 while cold or hot. Oscilloscoped the Crank sensor with spikes everywhere. New crank sensor same thing... Camshaft and Crankshaft sensors are ruled out by known good sensors. Going to EJS in two weeks!! Need help here...
02MoabTJ is offline
post #68 of 71 Old 04-03-2014, 07:46 AM
02MoabTJ
Well, guess what? No misfires (for now)
Of all things and after a year of screwing around trying to figure out this misfire issue plus $1000 spent, the deal is: Dirty/loose battery posts.
Wow.
Chrysler products seem to be VERY picky with this issue and pick up RF (static noise) really easy in the sensors... As for our sensors when looked at with oscilloscope, spikes were noticed always when enging was revved a little (putting more load on the battery)
Anyway, hopefully any of you with the same problem, check your posts ;-)
SEE YOU IN MOAB FOR EASTER JEEP SAFARI ! !
02MoabTJ is offline
post #69 of 71 Old 04-04-2014, 10:08 AM Thread Starter
SpecialTwinky
Well my jeep got totaled on the way over to the dealership to get the new computer in it. Saved me 800 bucks and got me a new jeep from a guy rear ending me and causing the jeep to roll.
post #70 of 71 Old 04-04-2014, 10:52 AM
02MoabTJ
Well I hope you're okay and now we both have good-running Jeeps :-)
02MoabTJ is offline
post #71 of 71 Old 01-10-2015, 01:31 PM
yamazinger
1993 XJ Cherokee
i cant believe the engine is misfiring because the battery connections were crappy. The battery has nothing to do with the engine running, the alternator takes on the role of powering hte vehicles sensors and whatnot while running. I noticed you changed just about everything but the o2 sensor. I have similiar issues prob for the last 4 or 5 yrs but just adapted to driving differently so that i doesnt misfire. It has gotten worse recently, now when in gear the engine runs rougher and occasionally stalls. All these symptoms play back to it being the o2 sensor in case you problem comes back look at the o2.
yamazinger is offline
help please , misfire cylinder 6 , sahara
