Multiple cylinder misfire!!! - Page 4 - JeepForum.com
post #46 of 71 Old 10-06-2013, 05:05 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by TJJP77 View Post
Still nothing constructive I see.
If I think of something that others haven't already brought up, I'll post my recommendation...
Knuckelhead is offline
post #47 of 71 Old 10-07-2013, 10:22 PM
Roobicon
Watching this thread. I have the exact same issue on my 04 Rubicon with a little over 125k miles. Mine started having problem when it hit 117 degrees here.
2004 Roobicon
Clinging to my guns and my religion
Roobicon is offline
post #48 of 71 Old 10-08-2013, 05:11 PM Thread Starter
SpecialTwinky
So I put the new rail on and it does the same thing. What else should I do??????
SpecialTwinky is offline
post #49 of 71 Old 10-08-2013, 07:02 PM
squirt
Had the same 300 301 codes. changed/tried everything and more than what has been on this thread. Saw a post/ reply that Jerry B. laid down with regards to H2O....... Said it would pop the carbon off the exhaust valve stems if I do recall..... especially if you don't rev. the engine regularly above 3500 rpm. Got tired of the flashing CEL... Here's what I did.
Ran 35 hi-way miles at @80 mph. Got to shop and left running. Around 215 degrees hot, got 2, 1 qt. squeeze bottle's full of water. Ran engine @ 3750 rpm and squirted the two quarts of water down the throttle body. Lot's of steam/clouds produced.
Idled down, closed hood and hit the hi-way. Not a blinking light for the last year or so.
squirt is offline
post #50 of 71 Old 10-09-2013, 09:20 AM Thread Starter
SpecialTwinky
Should I mist the water or pour it in straight from the bottle?
post #51 of 71 Old 10-09-2013, 10:43 AM
doublins
mist!
98 TJ Street Sleeper- 408ci Stroked Magnum V8
My Magnum V8 Build Thread:
doublins is offline
post #52 of 71 Old 10-09-2013, 02:01 PM Thread Starter
SpecialTwinky
How much water should I use
post #53 of 71 Old 10-09-2013, 05:29 PM
squirt
I used two, 1 qt ketchup bottle's. I did this right after I ran about 27 hi-way miles and 3 slow-way. Took the snorkel off the TB and then revved to a steady 3500 rpm. To compare the amount of water being shot, think of when you have to re-leave yourself. If you know what I mean. Not trying to be vulgar with that statement but it best describes the flow of water. The whole event took about two minutes. A lot of steam in the exhaust. Re-snorkeled and immediately got back on the hi-way. Entrance ramp I floored it taching out at 4500 between shifts (auto) got off next exit and did the same thing back. I've not had any codes or misfires since.
Yes, some will say it could have hydroed the motor, but at 3500 rpm I didn't think so.
Worked for me... could be a fluke.
Last edited by squirt; 10-09-2013 at 05:34 PM. Reason: Had to add the steam sentence and the ketchup bottles were the squirt kind.
squirt is offline
post #54 of 71 Old 10-09-2013, 06:00 PM Thread Starter
SpecialTwinky
I'll try and see what happens
post #55 of 71 Old 10-09-2013, 06:08 PM
Roobicon
Then come over and do mine
2004 Roobicon
Roobicon is offline
post #56 of 71 Old 10-13-2013, 10:23 PM Thread Starter
SpecialTwinky
Seems to have worked. I'm going to take it on a long drive tomorrow and see how she runs. Thanx for the help everybody!!!
post #57 of 71 Old 10-15-2013, 03:43 AM
squirt
I've been asked if there were any codes that came up when I did the water treatment. No I didn't although I probably should have. If you do just disconnect battery for 15 min. or so to clear PCM trouble codes.
squirt is offline
post #58 of 71 Old 10-16-2013, 04:02 PM Thread Starter
SpecialTwinky
It is still happening! What should I do now?
post #59 of 71 Old 10-16-2013, 04:43 PM
squirt
Being the basic's, Spark plugs, Compression test, New coil rail if old tested bad, Fuel pressure OK. Battery test's good under load.
As for sensors CRANK-PS, CAM-PS, TPS, MAP SENSOR, CLEAN IAC. Over the last few years I have replaced all sensors, coil rail as one coil tested low on ohms on the old one. And all the "tune up" items.
when I got the 300, 301 codes everything above was new or serviced.
Did the sea foam "heat soak" deal a couple of times. All that did was send it to limp mode.
Read where Jerry B. had talked about "popping" the carbon off the exhaust valve
stems. Also read that the valves need to "rotate" in their guides to keep themselves clean. This only happens I'm told when the RPM's are 3,000 and up.
Jerry said to trickle the water. I sort of streamed it.
Guess I lucked out....
But then what the heck do I know.......
squirt is offline
post #60 of 71 Old 10-16-2013, 05:27 PM
Roobicon
I've been watching this thread because I have the same issue. I'm thinking the answer to the question is engine swap...perhaps a nice 5.3L V8.
2004 Roobicon
Roobicon is offline
help please , misfire cylinder 6 , sahara
