Multiple cylinder misfire!!! - JeepForum.com
post #1 of 71 Old 10-03-2013, 09:19 AM Thread Starter
SpecialTwinky
I'm pretty sure that this has been discussed multiple times but I can't find what I am looking for. I have a 2002 jeep wrangler Sahara. It has a straight six and cylinders 1 3 4 5 &6. I can't figure out why it is doing it. I have changed the plugs and changed the ignition coil rail. I have also checked the cylinder compressions and they are all good. Does anybody know how I can fix this problem? Thanx for your help.
SpecialTwinky is offline
post #2 of 71 Old 10-03-2013, 11:16 AM
jkp
Check the crank position sensor. That's what the computer uses to fire the ignition at the correct time.
'92 Islander
'06 Rubicon
jkp is offline
post #3 of 71 Old 10-03-2013, 03:25 PM Thread Starter
SpecialTwinky
What do I need to do that? I have never checked a sensor before.
post #4 of 71 Old 10-03-2013, 03:58 PM
jkp
I think you can use an ohmmeter and test the resistance to see if it's shorted.
Other than that, there's not a good way to check it that I know of.
If it's the original one, I'd replace it.
'92 Islander
'06 Rubicon
jkp is offline
post #5 of 71 Old 10-03-2013, 06:35 PM
TJJP77
TJJP77's Avatar
You would need access to an oscilloscope to check the output of the CPS and verify that the signal has the proper "waveform" to diagnose it properly.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #6 of 71 Old 10-03-2013, 08:42 PM
silver97tj
silver97tj's Avatar
Hi all
Quick and dirty. wait till night and pop hood open, startup if is arcing you will see it right away..............................
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #7 of 71 Old 10-03-2013, 08:55 PM
TJJP77
TJJP77's Avatar
Originally Posted by silver97tj View Post
Hi all
Little harder on an '02 - it doesn't have plug wires to arc. While it's possible to get some arcing from the coil to plug boots, it's not terribly likely if the coil rail is installed properly and the boots aren't torn or damaged.
Chris
'02 Sahara
TJJP77 is offline
post #8 of 71 Old 10-03-2013, 09:07 PM
goodwrenchdave
So i'm assuming your setting p0300 at least and since you know the cylinders p0301,303,304,305,306? any others??
pull a sample of your gas from your fuel rail into a glass and let it sit for 1/2 hour. any contaminants, water? is it murky or clear, Do you have access to a scanner? can you check exhaust backpressure...it can cause misfires.
Do you drive it nice or hard.
how long have you had these misfires. any particular condition for them happening? highway speed, under acceleration, idle , hot , cold?
mileage please
goodwrenchdave is offline
post #9 of 71 Old 10-03-2013, 09:42 PM Thread Starter
SpecialTwinky
I just naught the jeep and it started misfiring a week or two after. I changed the rail and drive it around for thirty minutes that same day and it was fine. When I jumped in it the next day it happpened. It usually happens around twenty minutes of driving at any speed. It has just over 120k. I took it to a mechanic and he didn't know what was wrong. He said the wiring looked good to the ignition coil.
post #10 of 71 Old 10-03-2013, 09:42 PM Thread Starter
SpecialTwinky
Bought not naught. Sorry
post #11 of 71 Old 10-03-2013, 09:45 PM
chris142
What type of plugs are in it now and what brand?
Usually a Crank senser works or it dont. Since it does run I would assume that its ok.
How much fuel pressure you got?
chris142 is offline
post #12 of 71 Old 10-03-2013, 09:51 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Have you thrown a cel and if so what were the codes?Your stating a multiple miss fire but nothing on a code?You need to elaborate a bit more.Is this a manual or an auto?
GOLENJEEPTJ is offline
post #13 of 71 Old 10-03-2013, 10:22 PM
goodwrenchdave
Do you have a warranty as you just bought it?
sounds almost like it was sold because of this problem.
reading material.... not saying it's this as it has to be diagnosed but:
http://www.wjjeeps.com/tsb/tsb_wj_0900303.pdf
remember this can get expensive fast!
A very simple check is to just decarbonize first and check results.
post #14 of 71 Old 10-04-2013, 06:47 AM
aTX427
Run old school standard copper plugs, buy some Mopar wires, change the CPS with a Mopar sensor and check your ground straps. Stay away from the fancy plugs and cheap Chinese sensors.
aTX427 is offline
post #15 of 71 Old 10-04-2013, 10:31 AM Thread Starter
SpecialTwinky
I just put brand new Bosch Double Platinum plugs. The codes were p0300 301 303 304 305 306. What are mopar wires and how do I change them? And it is an automatic
help please , misfire cylinder 6 , sahara
