Multiple cracks in TJ hardtop - JeepForum.com
post #1 of 14 Old 11-05-2012, 07:53 AM Thread Starter
johny84
So, I have multiple cracks in my hardtop, just above the driver seat. Is there a way to fix it at home ?
It makes driving in the rain very annoying, since i'm getting wet whilst sitting in the car
johny84 is offline
post #2 of 14 Old 11-05-2012, 08:47 AM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
TheBoogieman is offline
post #3 of 14 Old 11-05-2012, 01:37 PM
blubaru2002
Bondo Fiberglass resin jelly. Easy for hardtop DIY repairs.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #4 of 14 Old 11-05-2012, 08:45 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You should read the second link. Hardtops on Jeeps are not made from fiberglass, they are SMC and require a resin other than the polyester that is used on conventional fiberglass work if the repair is structural.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 14 Old 11-06-2012, 07:42 AM
blubaru2002
I am aware that the hardtop is made of SMC and not fiberglass. I opted to use fiberglass anyway when I repaired my hardtop. It has held up fine. I suppose only time will tell.
post #6 of 14 Old 11-06-2012, 08:05 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Attachment 502767
Attachment 502766
Attachment 502765
Would you do the same to several cracks on top where it flexes?
I am Savvy
mrblaine is offline
post #7 of 14 Old 11-06-2012, 08:18 AM
asim04LJ
When I bought my Jeep wrecked, the front portion was broken off and near the rear window was a crack in the hardtop. The body shop used fiberglass resin to fix it and it was holding up good since 2008 until last year the same crack showed up and a sunken seam formed where the front portion broke off.
After the winter, I'll be looking for the right resin or never put the top back on.
asim04LJ is offline
post #8 of 14 Old 11-06-2012, 08:46 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Evercoat and others produce a SMC specific resin. When I worked at a body shop it was my job to do all the fiberglass related repairs. Not that I was particularly good at it, but because I was a lot better at it than anyone else.
I am Savvy
mrblaine is offline
post #9 of 14 Old 11-06-2012, 08:52 AM
blubaru2002
Good point. Probably not. But I would say that besides where the hardtop flexes a lot on the roof, the fiberglass stuff I used works just fine. My repair is holding up well to the door shutting directly on it.
post #10 of 14 Old 11-06-2012, 09:02 AM
asim04LJ
Thanks Mr. Blaine. I'll look into Evercoat.
asim04LJ is offline
post #11 of 14 Old 11-06-2012, 05:55 PM
tjdriver
Kitty hair is what you need.
tjdriver is offline
post #12 of 14 Old 11-07-2012, 07:50 AM Thread Starter
johny84
First, thank you all for the responses..
The story is that a few years ago a piece of marble stone fell off a building and cut straight through the hardtop of the jeep which was parked next to the building and landed on the driver seat
I got it fixed at a shop at the time, but few years later cracks began to form and now it leaks pretty bad..
Attached are pics from the inside and outside
johny84 is offline
post #13 of 14 Old 11-07-2012, 08:03 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That example is exactly why polyester based products don't work well on SMC or polyester that is not SMC specific.
Those areas are large, flexible and fairly flat which lets them expand, contract and move around a whole bunch and if you want the repair to last, you must use SMC compatible repair materials.
I am Savvy
mrblaine is offline
post #14 of 14 Old 11-07-2012, 01:11 PM
jscherb
X2, I agree with Blaine. To do a permanent repair on the area you've pictured, you're much better off with an SMC-compatible resin.
This one is a likely case of "do it right or do it twice" .
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
