multi function switch woes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > multi function switch woes
Memorial Day Weekend Sale Starts Friday-Tuesday 10% off + New DEAL OF THE WEEK at ROCKRIDGE 4WD!Deep discounts on Jeep Posi lok kits
Unread 07-16-2007, 03:33 AM   #1
thdrhntr
I recently added OEM fog lights to my Wrangler as they did not come with them.
I have a 06 and the only thing I had to do was add the lights and the multi function switch. I noticed this morning while driving to work that I don't have any turn signals nor emergency lights. I know that I have to go to the dealership to have the fog lights upgraded into the system, but why don't the turn signals and the emergency light not working ?, other than Chrysler sold me a defective switch.
thdrhntr is offline   Reply With Quote
Unread 07-16-2007, 06:14 AM   #2
truckin88
make sure that you have the harnesses in tight, make sure you brought the relay over from the one you took out, looks like a small black box, on the back of it. I had to take apart the old multi function, to release the female connectors.
This is my install of foglights on my 06 X you may be prewired.
http://www.jeepforum.com/forum/f9/put-fogs-my-2006-jeep-wrangler-x-407420/
truckin88 is offline   Reply With Quote
Unread 07-16-2007, 06:17 AM   #3
Mayfair_Jeeper
Yep, its your relay. Pull it off of the back of the old one and pop it into the slots on the new one. I made that mistake too
2006 Jeep TJ X Modded with toys
2008 Jeep Liberty Sport Stock
1987 Cherokee 4.0 Renix...Build in Process
Mayfair_Jeeper is offline   Reply With Quote
Unread 07-16-2007, 02:52 PM   #4
thdrhntr
Thanks truckin88,
I found the relay in back of the old switch and added a relay for the fog lights in the black box in the engine compartment. Everything works, thanks for the pics.
thdrhntr
Unread 07-16-2007, 07:14 PM   #5
truckin88
np, if you are prewired, you should be good to go, I figured it was the relay on the back of the switch
